Storage door construction ideas?
Alan Tolchinsky
>HI All, I just built a storage/bench that's 8 feet long by 33" tall. It's all made of 3/4" B/C plywood. Now I want to add doors to this to conceal all the stuff in it. It will have a face frame mostly because I want to make one. What kind of doors would you make? I was thinking of 1/8" masonite with a 1x3 wood frame around it simply glued on . What do you think? Thanks for any ideas. Alan
Re: Storage door construction ideas?
Me too ...
Mike Farinella
>I did the same thing as you Alan but I used 1/4" hardboard for the panels. I also splined the corners of the mitered doors for extra strength. Regards.
Do something that you need practice on
Rob Sandow
>When I build shop cabinets, I usually build them out of cheaper materials but try to use methods that are suited to furniture or finished cabinet construction. In this case, you can't go wrong by building some frame and panel doors using M&T or cope and stick, using pine or plywood for the rails and stiles and masonite for the panels.
Rob
ScottS
>I have to admit, for stuff like this I go Cheap and Easy: cut a 3/4" plywood (or melamine) panel to size, iron on some edge-banding, drill for hinges, and install a knob. Much easier and far less time than building a "real" frame and panel door...
Alan Tolchinsky
>Thanks all for the ideas. Unfortunately I don't have many tools here so I can't do many machining operations. I'll have to stick with the 3/4" ply doors or the fake masonite with wood frames type. Thanks for your suggestions.
