Opinions on grain on drawers
Doug in Denver
>I am building an entertainment center mostly out of Honduran mahogany. The bottom section will look pretty much like a squat sideboard. It will have three 24" wide drawers in the center - the drawers are one top of each other, not side by side. For the drawer fronts I am using quilted Bubinga veneer - a fairly dramtic grain.
Here's my question I would like your opinions on. I have three sheets of veneer cut from the same log in sequence, so the three sheets look pretty much identical. Each sheet is about 86" inches long, so I can easily get the veneer for all three drawers from one sheet of veneer. The grain on each drawer would thus be similar, but not identical. Or, I could cut each drawer from the exact same spot in each the three sheets, such that the drawers fronts would be more or less identical. Setting aside any issues of whether that might waste veneer (I dont really think so), but focusing only on asthetics, which would you do? I don't want to make three identical drawers and have it look stupid.
