OT: Migrate from small HD to big one
arw01
>What's the preferred freeware for moving from an XP home system on a small HD to a large HD without reinstalling everything from scratch?
Thanks
Alan
arw01
Thanks
Alan
I don't...
Hoa Dinh in Alameda
>migrate HD, unless there is a compelling reason. No matter what they say, changing HD may open a can of worms....
I would just add a second HD to the computer, leaving the existing HD as is, and then moving data (not programs) from the old HD to the new one.
-- Hoa
The programs are taking all the room!
arw01
>The programs are taking all the room, and this particular user has a difficult concept of folders, let alone another drive!
I have a knoppix image coming down, but it will be a few hours before finished. I can dd if there isn't a better program out there.
Alan
Re: OT: Migrate from small HD to big one
Bill Hammond
>Your new HD should come with a utility to do this. Just follow the instructions carefully. If it's not with the drive go the their web site and look for it.
Ray SW Ohio
>I installed a bigger hd in my pc. It came with software to move everything to the new hd. I haven't had any problems. I moved Windows XP Pro and it boots up and runs fine, just like it did before moving everything. My 2�.
Re: I don't...
Joe in a Cleveland suburb
If you take this route, keep in mind your new drive is likely to be faster than the old. Could be noticeably faster. If you have an app that is sluggish or very drive needy (does a lot of read/writes), you might consider uninstalling it and installing it onto the new drive. Don't forget about defrag too.
I recently added a big drive to my pc. I removed then reinstalled a game (Call of Duty - United Offensive) I play online a lot. It made a huge difference in performance. Loads a lot faster too.
Just a thought.
Joe
Rob Hix - King George, VA
>Alan,
What I use at home and at work is Acronis True Image Pro (www.acronis.com). As usual, I have no affiliation with the company. Just a very satisfied customer. Let's just say that this software has save my hind end a couple of times.
It is not that expensive, but for a one shot thing you can probably use the trial verison. If I remember correctly it is fully functional, but you may want to check.
Rob Hix
Tom
>Ghost, Acronis or several others. You can buy them, or google Hiren's boot cd. It comes with earlier versions of Ghost, True Image and a few others I can't think of, as well as a whole host of other extremely useful apps. As the title says, it is a boot cd. It won't cost anything to try. Install your new drive in the same pc, format it, then boot to the cd and use one of the above utilities to make an image of your old drive on the new drive. Then make the new one your boot drive and try booting to it. If that doesn't work, try one of the other apps. I've imaged and restored to both ghost and true image using the free boot cd. Strangely enough, I've had problems with the newest commercial version of both Ghost and TI imaging (although that was imaging to a dvd, a different proposition). In any case, it's free, and you are not messing up your old drive at all.
Whenever I buy a new computer
Johanna
>I pay a tech to copy my stuff from the old hard drive to the new one. Costs me about $70 and is worth every penny since it would take me much, much longer to do it correctly.
Re: OT: I used Knoppix to make the move
arw01
>computer reported to be working perfectly.
A dd if=/dev/hda of=/dev/hdb
then a parted session to expand the NTFS partition to full disk size.
Alan
arw01
>Maxtor max blast. won't work with a machine that doesn't have a floppy. I refused to install one just for their antiquated program to work.
It also did not work on the last system I changed a hard drive on.
Alan
Lee Gordon
>Can you not copy the contents of the MaxBlast floppy onto a CD?
Re: OT: Migrate from small HD to big one *LINK*
Curt Harms
>Here's another option: Image for DOS & Windows. I've done backups and restores with no issues. I believe they also have a Linux version. I don't know how functional the trial version is. The company also makes a multi-boot and partition management program, Bootit NG. One caution with any image program-make sure the resulting CD's, DVD's or whatever are readable. Nothing like having an 8 CD image set and have the 8th one abort due to corrupt data. DAMHIKT.
Curt
Terabyte
