Rail & Stile Set
Rail & Stile Set
Rail & Stile Set
Ole' Salty
>Hi. Has or is anyone out there using the Freud "One piece Rail and Stile set". If so any imput would be appreciated.Tnx.
Re: Rail & Stile Set
del schisler
>i have the single stile and rail I belive i got it from price cutter It work's fine Both should work alike they probly will give you a sheet for set up price cutter did here is a site to show you how to set it up
http://www.pricecutter.com/product.asp?pn=P15-3825&cn=243800&bhcd2=1168952550
Charles M
>While the pricecutter bit is somewhat similar in concept, the Freud 99-290, 99-291 and 99-293 bits have the advantage of making both cuts with the material face down so any inconsistency in stock thickness will appear on the back of the door.
Ole' Salty
>Thanks very much.
