Dad's first Drill-press restore finally finished
Bart Leetch
>I built a base & covered it with laminate for the drill-press with a drawer & place for the switch & painted & mounted another motor. I intend to build a wider wood table for it about as wide as the base which is about 16 1/2" I only have just so much room anything bigger will be drilled on the floor model drill-press.
