Tip: Archiving your WC aquired knowledge
Dominic Greco
>Hi everyone,
Did you ever get so much great information here at Wood Central that you want to save it? But you want to save it JUST the way you saw it here? Something to carry out into your shop and refer to as you work? Or maybe you just want to save an entire thread to your computer (discussion) so that you can have an archive of all that was imparted to you during your "search for woodworking knowledge"?
If so, I just thought I'd pass this simple "archiving" tip along to you all.
First off, you need a program that will allow you to write to a PDF. While there are many out there, the one I use is a free ware program called PDF995. Using this link, you can download and use for free. This file will add a PDF995 Virtual Printer. Simply print to this "Printer" and it will create a PDF file.
Secondly, set your forum preferences Display Style to "Guestbook", and Sort Order to "Oldest First". This way, it will display and print out your question first, and all the replies you've gotten after.
After you've successfully completed the steps above, browse to the discussion thread you want to save and bring it up. Then use your browswer's PRINT command to print to the PDF995 Printer.
The discussion thread will print just as you see it on the screen. The nice thing is that you can now save this PDF file to your own Woodworking Wisdom directory.
And,....that's it!
See ya around,
Dominic
