Question on cabinet hinges
Johanna
>Has anyone ever used the Blum mini clip on hinges that require a 26 mm hole (as opposed to the standard 35mm hole)? If you have, is the edge of the cup hole the same 6 mm distance from the edge of the door as it is for the 35 mm size? I got the hinges, but no instructions.
