Finishing in a basement shop
Carlos Clarke
>My shop is in my basement.
In the summer I can apply a finish to a project
and leave the basement windows open(I generally
use an oil) and get minor grumbles about the smell
from the family.
In winter I apply a finish during the day and leave
the windows open until evening. Then I really hear
about the smell. I'm also concerned about the temperature
both for the project and my oil bill.
How does everyone else deal with finishing in a
basement? (I no longer have a garage. I converted
it to a family room.)
Carlos
Re: Finishing in a basement shop
Ed O'Neill
>Carlos, for years my shop was in the basement and I dealt with your problem. I eventually went to water base products. I know leaving oil products behind is tough but my familes health was the determining factor. The purests will go nuts reading this but the odor and the chance of fumes causing fire or even explosions kept me awake at night. Ed
John Ergle in SC
>I have the same situation, and I basically agree with Ed. In the summer, I often will spray oil or lacquer outside, then bring it in after it dries (dries a lot quicker outside anyway). But in the winter, I typically use only shellac or water-based polyurethane, brushed or wiped on. No real smell, and those products dry quick enough I don't have to worry quite as much about dust settling and causing problems. If you haven't tried water-based products, I bet you'll be pleasantly surprised. I've gotten where I really favor them over oil for most projects.
Mitch from TN (formerly from NYC)
>Guys,
I'm in a similar situation. Can you tell me the specific products you use, especially the water based poly?
Thanks!
Mitch
No Problem......
>No Wife. The divorce cured the problem. She can't smell it from the next state. AND, according to the decree I don't have to listen anymore.
bill tindal, E.TN
>you didn't say where you live, but in the moderate climates it gets warm inside cars on sunny days. I flash off solvent by putting the object (if it is small enough, in the van or car on a sunny day. Around here it will get into the 70's inside the car in full sun. The I bring it in in the afternoon. Wife worked with solvents as part of her job so things like xylene are not objectionable, especially if it means something useful for the home is at hand.
Pat in Spokane
>I have a similar situation and am considering installing a bathroom fan above my finishing area. While it may not a perfect solution, I would think you can get decent enough air movement (50-300 CFM) out of a bathroom fan, vented to the outside, which should at least mitigate the problem.
Take my wife.......
Tom Pilsbury (Chicago)
>Please!
You knew that was coming, didn't you? :-)
Carlos Clarke
>I'ved tried water based products before. I don't like
the look. I much prefer the warmth that an oil based
product produces.
I have a walk out basement. It opens up under a deck.
I was considering putting a small shed there and
temporarily heating it with an electric heater when
I need to finish something.
That would also give me back my shop since I wouldn't
have to worry about dust any longer.
Water-based poly
John Ergle in SC
>Mitch,
Nothing fancy - mostly just off-the-shelf Minwax poly in the blue can. My only local source is the Blue big box, and I've always used mostly Minwax products. I did use a commercial water based poly when finishing my bedroom floor, but it was more difficult to use and much more expensive.
I've already got one, thanks.
Don Henthorn
