Drill press runout
Ink Man
>I have a Craftsman drill press, which I bought new 5 years ago and has been very lightly used since. Because of several moves across the country, I have just recently begun to use it extensively. While it is running, visually it seems that the bit wobbles considerably. The holes I am drilling also appear to be somewhat sloppy and elongated (not truly round.) I have tried several different (new) bits and get the same result. I am going to remove the chuck and clean up the arbor, as well as make sure their are no burrs or any other problems which may be causing these issues. When I have done this, I am going to measure the runout using a dial caliper. I understand that I will need to chuck a straight, round bar to use as a reference. Does anyone know where I can find something this item? Or if anybody has any tips on measuring/correcting runout on a drill press, I would greatly appreciate any advice.
Thanks
Tim
