Band Saw Blade Tension?
Brint K in Atlanta
>I just installed a new Iturra spring in my 14" Delta bandsaw since my OEM spring was bottoming out when I tried to tension it for resawing. The Iturra literature reads, "We recommend a maximum tension of 15,000 psi for the 1/2" wide blade of any type on the Delta 14" bandsaw" (I'm using the 1/2" Woodslicer).
Since I was dissembling the bandsaw a little bit, I thought I'd pick up my copy of Lonnie Bird's The Bandsaw Book for some guidance on maintaining my cool blocks (I'm still pretty much of a novice on the bandsaw). In this he says (in several places) that spring steel blades (which is what the Woodslicer is) require 25,000 psi.
Now, I doubt I'm expert enough to know (or make) any difference in cut quality by changing tension levels. I do notice that the Iturra is much stiffer than the OEM spring. But now I'm wondering: just how tight (according to the scale on the bandsaw) should I be tensioning my Woodslicer for resawing? (And yes, I always release the tension after sawing).
Thanks --
