OT: Mechanical question, rear axle as winch
Luke Herzberg
>Howdy folks! A question for the collective WoodCentral genius.
Imagine if you will...an ol' rusty pickup parked, up on blocks and bare rims on both sides of the rear. If somebody were too cheap to invest in an actual winch and strung a rope around the rims in the following manner, would it work?
Rope takes a couple wraps around one rim (capstan), then through a couple strategically placed blocks, turns 180 back to the rim on the other side around which it is wrapped (winch). Both rims are turning forward (normal pickup-go-forward direction were it not tireless, jacked up on blocks and trussed like a Thanksgiving turkey).
In my way of thinking, the work should get distributed to both rims, with any difference due to slippage or change in diameter as the rope wraps up on the winch side accomodated by the diff. Does this seem logical? With equal work on both rims and equal tension throughout the rope, the capstan rim would be idling? Or is it doing the work and the winch rim just taking up slack? I'm just trying to avoid one of those forehead slapping moments immediately after I spend the time to make it happen.
Original idea was using one rim only as the winch with the other tire on the ground, but doubling the speed was not helpful, plus the spiders get an extra workout.
Whaddya think?
Thanks,
Luke
