I let the PUFF out of my blower motor....
>I have been drawing and redrawing a plan for a down draft table based on a furnace blwoer I have been saving for twenty years.
Today I got it out and sat it on the base. Decided I should try it out and see which wire set which speed. Hooked white to white (sort of dingy tan, but what I took to be white.) Black to black and green to green. It ran for about ten seconds and then smoked and burned. I was going to try the red wire next but I think I'll have to go to plan B. Does anyone see an obvious error or did it just die of dry rot? I have no wiring diagram.
Re: I let the PUFF out of my blower motor....
Don Evans
>How do you know what voltage it is? 120v or 220v, assume you where trying it at 120v?
You don't really say in plane language what the motor really did, that's helpful somethings.
Don
Don Evans
>Barry:
I went back and reread you message, the 10 sec run and smoke and burn I missed first go round, that's plane enough, sorry for misread.
Don
>Don, I was confrinted with six or eight wires. (I took this thing out of the Air handler for a heat pump years ago.) I had taped off three of the wires with electricians tape. They ahd spade connectors on them. So, This time I assumed they were the ones that had been in use. Black, Green and What passed for white (dingy tan). The probelm was that there were two dingy tan/white wires. One with spade conector and one without. I decided to try the three that were taped off, thinking I had done that as a reminder to myself. There was also a red wire with a space connector. I thought I woudl try that later, hoping it was a second speed. When I pluged this thing up the motor ran sort of gently and slowly. Appearred to be a few hundred RPM. I was disapointed in that as I wanted huge volume. At that point I realized it was making a crackling noise and I listed with my ear near the motor for a second or two, deciding if it were debris in it or if it were really arcing. It was really arcing. By the time I made the decision it was burning in the area the wires enter the motor and continued to burn after I unplugged it. For about thirty seconds.
I guess I'm trying to decide if I killed it by hooking the wires up wrong (Useful to know next time I get one) or if it just died because of age and degredation of internal insulation. I never got to the part of switching the wires around for various speeds.
Bruce Wrenn
>Key words- air handler for A HEAT PUMP. This means that motor was most likey a 220 volt motor. By using 220, the heat strips and motor can be supplied by same 220 circuit, without having to have a neutral.
