W & M Highboy???
W & M Highboy???
W & M Highboy???
On page T36 of the most recent issue of WOODSHOP NEWS there's a beautiful William and Mary highboy. The front facade (drawer fronts and bottom apron) are all matched crotch veneer.....at least I assume it's veneer. Which leads me to my question....
If that front facade is veneer, it appears to me that the grain on the veneer is vertical. The grain on the substrate members must run horizontaly. It also surely must be solid lumber. This creates a prpendicular relationship between the veneer and the substrate. How do you get away with that? Do you have to veneer the inside of the drawer fronts and the apron to balance things out? If so, do you run the veneer verticaly as was done on the face? Is the substrate likely from the same species as the face veneer or from some secondary wood?
I've always thought this particular look (matched crotch fronts) was about as pretty as it gets. I've also pondered all these questions.
Educate me oh learned ones.......
Re: W & M Highboy???
Stephen Shepherd
Joe,
I just checked out the picture of the William and Mary Highboy. Not much detail, but here is what was done in the eighteenth and nineteenth century on similar pieces. Some were veneered on the inside with the grain matching the general direction of the front, not necessarily the same species. And some were not veneered at all. I have a nice Empire style chest of drawers made of pine with cherry as a secondary wood and the drawer fronts are veneered with verticle grain crotch mahogany veneer. There is also mahogany veneer cross banding between the drawers on the framework. There is no backing veneer on the inside and the only damage is minor chipping to the edges of the veneer, not bad for a piece 160+ years old. If I were to make a reproduction of this piece I would veneer the inside (matching grain direction of the face veneer) to counter the difference in shrinkage. The old growth wood that our ancestors used is/was of a higher quality and probably doesn't move as much as second or third growth timbers.
Stephen
