Router woodworking
Router woodworking is one of the most versatile and useful skills you can learn in the shop. A router can create decorative edges, cut perfect grooves, make joints, shape wood, and even produce beautiful signs and inlays.
Getting started with routers
Basic router types:
  • Fixed-base router – Great for edge work and when you want a consistent depth.
  • Plunge router – Ideal for cutting stopped grooves, mortises, and working in the middle of a board.
  • Combo kit – Comes with both bases so you get the best of both worlds (highly recommended for beginners).
Most useful router bits for beginners:
  • ¼” and ½” straight bits (for grooves and dados)
  • Roundover bits (common sizes: ⅛”, ¼”, ⅜”)
  • Chamfer bit
  • Cove bit
  • Flush-trim bit
  • Rabbeting bit
  • 45° chamfer and Roman ogee for decorative edges
Essential router techniques
  1. Edge routing
    Always use a router table or a straight edge guide. Move the router counter-clockwise on the outside edge of a board (left to right on the end of a board). This pushes the bit into the wood for better control.
  2. Router table basics
    A good router table turns your router into a mini shaper. It’s often safer and more accurate than handheld routing for edge profiles.
  3. Making grooves and dados
    Use a straight bit with an edge guide or on a router table with a fence. Make deep cuts in multiple shallow passes (usually ⅛”–¼” per pass).
  4. Template routing
    Use a flush-trim bit with a bearing and a plywood or MDF template. This is how you make repeatable curved parts, signs, and inlays.
Safety tips (very important with routers)
  • Always wear eye and ear protection (routers are loud!).
  • Never remove more than ¼” in a single pass on hardwoods.
  • Keep both hands on the router at all times.
  • Use featherboards and push pads when using a router table.
  • Let the bit come to a complete stop before setting the router down.
Popular beginner projects using a router
  • Cutting boards with decorative edges
  • Simple picture frames or box lids
  • Sign making with lettering templates
  • Drawer boxes with rabbeted or dado joints
  • Slab flattening (with a large router and sled)
  • Dovetail and box joints (with jigs)
Would you like me to give you a specific recommendation based on what you want to do? For example:
  • First router purchase advice
  • How to build a basic router table
  • Best bits for a certain project
  • Techniques for a particular joint or edge profile
Just let me know what you’re trying to build or learn!
Title: Router woodworking
Author: Woody Barker
Original URL: https://www.woodcentral.com/-/router-woodworking/
