Hello Peter,
Unfortunately our maintenance yesterday on lu-shared02.dapanel.net wasn’t successful using the automated path we had used on another stubborn node. We’re going to move ahead with a more drastic node rebuild tomorrow October 30th starting at 10PM Amsterdam Time (UTC +1) – check this time in your timezone here: https://time.is/compare/
The existing node will be taken offline for a final data sync with the new node (we already started the bulk of the sync yesterday) to grab any remaining changed files, and then the new node will be brought back online with the same data intact.
We will be keeping the old node around if we run into any unforeseen issues so it can just be powered back on. We’re planning the same 3 hour maintenance window, with up to 2 hours of actual downtime to complete the maintenance.
Nothing is required on your end, IP addresses won’t change and we will retain the full copy of the current node to quickly restore should we encounter any issues.
We apologize for the amount of notices and maintenance required, we just haven’t had a node this stubborn to update before and we can’t leave it in the current state long term. So we’re going with the larger impact – full rebuild – plan to just be able to call it done and know the node is on a new OS and new DirectAdmin licensing system with better software support.
