Corner clamps for woodworking
Corner clamps (also called corner vises or 90-degree clamps) are essential tools that hold two pieces of wood at a precise right angle while you drive screws, nails, or apply glue. They’re especially useful for assembling boxes, frames, cabinets, and picture frames.
Types of corner clamps
Here’s a quick comparison of the most common styles:
TypeBest ForPrice RangeProsCons
90° Corner Clamp (screw-type with two jaws)Small boxes, frames, miters$10–$35 eachInexpensive, compact, easy to useLimited throat depth, can slip on large pieces
Band Clamp / Strap ClampLarge frames, hexagons, odd shapes$15–$40Even pressure all around, great for irregular shapesSlower to set up, less rigid
Pipe Corner Clamp (uses ¾” or ½” pipe)Large cabinets, heavy frames$20–$60Very strong, unlimited sizeRequires pipe, heavier setup
Aluminum Alloy Corner Clamp (fixed 90°)Quick assembly of small projects$8–$25Lightweight, fast, good for beginnersLess clamping force, can dent soft woods
Kreg Corner Clamp (or similar specialized)Pocket-hole joinery$25–$45Designed specifically for Kreg jigsLimited to certain joint styles
Top recommendations by use case
  • Best overall for most woodworkers:
    Bessey WS-3 or Wolfcraft 90° corner clamps — strong, well-made, and reliable.
  • Best budget option:
    Anpro or similar cast-aluminum 90° clamps (sets of 4). Great starter set for under $30.
  • Best for large or heavy projects:
    Pipe-style corner clamps (Jorgensen or similar). You supply your own black pipe for any length you need.
  • Best for picture frames or delicate mitered corners:
    A good band clamp (Rockler, Pony, or the popular “ratchet strap” style).
Pro tips for using corner clamps
  • Always check for square with a reliable speed square or framing square — clamps can sometimes pull slightly out of 90° under pressure.
  • For miters, use clamps with padded jaws or add cardboard to prevent marring.
  • You rarely need just one or two — most woodworkers buy them in sets of four so they can clamp all corners of a box at once.
  • Combine with cauls (straight wood strips) to distribute pressure evenly across joints.
  • For very large carcasses, consider using assembly squares (aluminum or plywood) in combination with bar clamps instead of traditional corner clamps.
Would you like recommendations for a specific project (picture frames, boxes, cabinets, etc.) or a particular budget range? I can narrow it down further.
Little-known woodworking fact: The ancient Egyptians were using corner clamps made of wood and rope over 4,000 years ago when building their intricate sarcophagi. Some things in the shop never change!
Title: Corner clamps for woodworking
Author: Woody Barker
Original URL: https://www.woodcentral.com/-/corner-clamps-for-woodworking/
