Bleaching Walnut Sapwood ?
Brad Vietje
Brad Vietje
Hi Folks,
I got a large amount of fresh-cut walnut last May, and turned some of it right away, knowing that the sapwood tends to turn muddy grey-brown over time.
So -- now that the rest is 10 months old, is there a way to whiten up the sapwood that doesn't look like hell?
Here's a natural edge rough-out when fresh...
Outside:
...and inside:
Sure would be nice to turn something and get some level of white to the sapwood... Ideas or methods?
Thank you kindly, and safe spinning,
Brad Vietje
Newbury, VT
Re: Bleaching Walnut Sapwood ?
Rum
No idea on bleaching, but would be also interested to hear any ideas, I love the contrast on fresh walnut.. I had some very small turnings (spinning wheel hooks maybe 1/2" x2-3") that retained the contrast for no apparent reason I could ascertain.
The other thing I found that was interesting was if I packed the rough turned bowls in the turning shavings for a couple of months (taking out to air every week or so to avoid mold) it seemed to stain the white sap wood so you couldn't tell the difference, something about activating the thujon or?? something? Not sure if this is repeatable since my sample size was 10 bowls from one tree
Lyle Jamieson
Lyle Jamieson
When fresh like that, I use lemon juice to help retard the color change. Nothing will keep it that white but the lemon juice will keep the contrast and end up with a cream color instead of turning gray/brown. It works well on cherry too.
Bleaching is the only method that.....
JamieDonaldson
...I have ever found to work, and must be done while the sapwood is still fresh and white.
Brad Vietje
Re:  Bleaching is the only method that.....
Brad Vietje
Ahhh.... no free lunch, then!
The NE bowl shown was air dried in a paper bag, and still looks great, along with 5-6 others done last May. If we get a spell of weather above freezing, I'll get back out and finish turn them.
Just fishing around for an approach to use on the big log sections that were waxed, but not rough turned last Spring... Normally, I would be in a big tear to rough turn everything within a few weeks -- or even days, if possible. Was not something I could do last May/June, so now I may need to avoid the sapwood on the stuff in storage.
Wasn't aware that bleaching was commonly done as a preventive measure before the wood turned color -- I always figured it was done to return the wood to white. Good to know.
Safe spinning,
Brad Vietje
Newbury, VT
Guy Bratt
Jamie what do you use to bleach ?
Bill Blasic
Bill Blasic
I use Klean Strip Wood Bleach. Have had trouble finding the small boxes of the two part bleach so I bought the big version (gallon of A and a gallon of B) Won't run out ever again.
Alan Hollar
I have tried chlorine bleach with no success, and the 2 part caustic soda and hydrogen peroxide bleach with moderate success, though it is easy to get streaks of bleaching where you don't want them. The Part B for the 2 part bleach is a strong hydrogen peroxide which slowly loses potency as the H2O2 becomes H2O so larger containers can become less effective if stored for long periods of time
don stephan
Somewhere I read a suggestion that the discoloration is mold/fungus that grows until the green wood dries. Don't know if true, but seems reasonable.
Brad Vietje
Brad Vietje
Seems reasonable, Don. I've rough turned and air-dried a number of pieces that seemed as white as new many months later. I'll have to dig into some of the 1-yearr-old stuff soon (when warm enough), so I may experiment with getting some of the sapwood to lighten -- or not. Will still be nice Walnut, anyway, and some are about 30" in diameter, so even if I trim the yucky-looking sapwood off, I've still got a pretty big hunk of wood.
Safe spinning,
Brad Vietje
Newbury, VT
Bill Blasic
Bill Blasic
Alan I don't know the time limit but going on over ten years and it still works as good as the day I opened it. If you have 7 friends that works out to be about $11 a pint kit by buying the gallon size.
