Re: Finishing: buffing Qsn.
David Walser
I don't know that it's true that "most" turners finish their turnings using the Beal buffing system (or something similar). I know a lot of turners do, but I doubt its a majority of all work done. I generally use my buffing system on plastics or turnings finished with a film finish (shellac, lacquer, etc.). When I'm going for softer finish, such as oil/wax, I just buff the finish with a paper towel on the lathe.
To address your question re: white diamond leaving deposits in the wood's pores, cracks, and details. Yep, it does that. (Tripoli does the same on light colored woods, but it's not as apparent.) There are three possible approaches:
1. Don't use white diamond on dark colored woods. Buff with Tripoli, skip white diamond, and go on to your final wax buffing. Tripoli produces a fairly fine finish. White diamond produces a slight, but noticeable improvement. If a particular turning doesn't "need" slight benefit from white diamond, skip it.
2. Do a better job of filling all the pores and surface defects before buffing. If you're going for a gloss finish (if you're not after a gloss finish, you shouldn't be using white diamond anyway), the surface should be level -- which means the pores and cracks should be filled. Then, other than surface decorations you've added, there won't be anything for the white diamond to stick to.
3. Get good at removing the white diamond from the surface of the turning. For the bottoms of v-groove, you can use a card wrapped in a paper towel or tissue to remove the white diamond. Some use blunted dental picks for removing it from pores and cracks. Compressed air sometimes works. The stuff is soft and will come off if you can find a tool that will reach it.
HTH
