Finishing: India ink and top coat?
Henry (Raleigh, NC)
So after reading that India ink was the best way to get a 'good black' on turnings, I tried it, but only after false starts with dyes and non-pigmented version of India ink. Happy with the black, I then tried a shellac top coat (brushed) and "duh" it bled over to other areas. I should have expected that, but did not. This is on a piece of hard maple that I wanted to selectively color.
My next go at a top coat was going to be a solvent based lacquer or polyurethane, or perhaps a spray shellac.
Before I go through countless iterations/attempts/experiments/trials, are there tried and true means of stopping the bleeding of India ink when applying a top coat?
Thanks
Henry
Re: Finishing: India ink and top coat?
The ink you used may have been alcohol based. Shellac which is alcohol based might disolve the ink. I have had the ink run onto the rags that I use when I apply lacquer with a rub on technique. I will usually spray these turnings first if I can. That coat seals it and since I'm not rubbing the finish it doesn't smear it.
Dennis in Southern Oregon
India ink consists of lampblack (elemental carbon), water and often a bit of shellac as a binder. Coating it with more shellac or other alcohol-based finish can be expected to soften and spread the original carbon/shellac mixture. You need to apply a sealing layer of something that will not dissolve shellac.
Dennis
Mike Foster
I have done a few pieces using india ink as ebonizing. I use fixatiff or Kryon matte or clear coat to seal the ink and keep it from smearing. Probably work as a base for subsequent surface finishes as well, though I haven't tried that yet.
Lyle Jamieson
Lyle Jamieson
I have used ink for years but I do the entire piece with ink. If you dont have to worry about bleeding I finish it with Kiwi Black shoe polish.
Rob Wallace
For "ebonizing" various woods... *LINK*
Rob Wallace
.....I use Fiebing's (USMC Black) Boot Dye (one or two coats as needed), and then, when it is completely dry, I use spray lacquer (Deft) to seal the dye into the wood.
I do a fair number of collars and finials, and this method works particularly well, especially when costs of African blackwood continue to increase and the availability of it is decreasing.
Rob Wallace
Fiebing's Leather Dyes
Terry Scott
Henry
I spray with lacquer over the top of the ink
I first spray a quick thin tack coat.The product I use is dry in 10 seconds then I just build up from that.
If I think I am going to get myself in grief I wax with a boot brush
Thanks all!  Good ideas that I'll try
