Hunter Taper Hollowing Tools - Review
Phil Stivers
The Hunter small (3/8" tapered) tools arrived. The HF is 3 3/4" tall 3 1/2" dia. Opening is finished 3/4" and the walls are appropriately thin (without being see through.)
The tools consist of a straight tool, bent tool, and "back" or under lip tool. All on 3/8" tapered shafts. The back tool is only useful under a rim and is pulled toward you. The bent tool's #1 cutter is set at an angle while the back tool is angled and set recursive. The straight tool's #1 cutter is set straight with the operator in charge of canting the tool to ease it into the work.
The tools will cut aggressively but will also yield a smooth controlled cut when desired. I used a home made straight scraper to work the bottom. A definite need for this set.
I like the tools. This is about the limit for the tools in depth, but I got very little chatter. The little buggers cut like crazy!
