A potentially interesting surface enhancer *LINK*
charlie belden
Central Texas has suffered through a heat wave and accompanying drought this summer. When 99 degrees is considered cool you know it's been hot. And cattle and crops don't do well without water. I figured if Raiin Dances didn't help then perhaps a Rain Wand might work.
So when I went looking for something I could use to put falling rain drops on this thing I found something others here might find useful in a future piece - GOLDEN's Clear Tar Gel. Unlike other of GOLDEN's clear mediums this one's thin enough flow off a small brush but thick enough to hold its shape. Milky white when wet so you can see where it's been applied, it dries very clear.
Here's the raindrops effect done with Clear Tar Gel.
If you're looking for a surface enhancement and dropplets are what you're after - this just might be what you've been looking for. Imagine a single tear running down the side of a piece, originating from a crack or void in the wood. Or a bowl with beads of water forming on it. I think this stuff can be colored as well. A bead of wine on the rim of a goblet. Has some interesting possibilities.
more about this Rain Wand
