Sequoia Radica / Pay it Forward
David DeCristoforo
My "Pay it forward" offering from a piece of Charlie Belden's wonderful redwood burl. This piece is being shipped this week, along with several others, to a gallery "on approval". If it is accepted and (if and when) sold, I plan on donating all or part of the sale to the Free the Children Foundation, a cause that my daughter is very passionate about and actively involved in. If this does not pan out, I will fall back to Plan B. (No idea what that is yet!)
So… here is another "amphora". This one is sixteen inches tall and 4.5" at the rim. The body, embellishment and base are redwood burl. The stem and transition piece are ebonized rosewood. This one is much fuller in form than any of it's predecessors because I wanted to retain as much of the wood as possible. To help in visually balancing the larger form, I increased the size of most of the details. The narrow part of the stem and the transition piece, the "bulb" at the top of the stem and the embellishment were all "bulked up" a bit to add some "weight". I had considered some sort of detailing at the rim but I really wanted the wood to be the center of attention with this one so I left the rim alone. It's finished with lacquer and buffed to a satin gloss.
Re: Sequoia Radica / Pay it Forward
matt overton
Beautiful piece!
D Leydens
David, always like looking at your work. Another beautiful form and the wood is in the spot light. Very well done.
Another great piece in the series!
Fantastic !
charlie belden
David:
You're setting the bar pretty high for others in the Pay It Forward Project aren't you?
The flared top is seldom seen in turned hollow forms, but in this case it provides an opportunity to show off the beauty of the wood - in a very elegant setting. I think the choice of not attempting to embellish things was a wise one given the look of the wood. You have an innate eye, probably as a result of growing up with a woodworker for a father.
It's unusual for a son to follow in his father's footsteps. The son usually sees all the things the father must deal with in his profession - and shys away from going down that road. I suspect that your fathers love and passion for woodworking rubbed off on you - though you've pursued turning rather than flat work. Your dad was a master of joinery. You're well on your way to mastering turning.
Akways a pleasure to see your work.
David DeCristoforo
Thanx Charlie. I would like to clear up the common misconception that my father was a woodworker. He was not. He was a writer who wrote about woodworking. He also wrote about many other subjects. Concrete work, house building, plumbing and electrical systems, etc, He was a pioneer in the field of "Do it Yourself" writing and was considered to be the best at what he did. His legacy or, if you will, his "body of work", consists of books, not pieces of woodwork. In fact, you would be hard pressed to find an R. J. DeCristoforo piece. There are none to be had. He was able to cut and fit a perfect mortice and tenon or a set of dovetails. But the pieces seen in his published work are not furniture parts. They are photo props. Perfectly executed, beautifully photographed and illustrated, succinctly described but never to see any other purpose once the book was done. I am not sure why it is important for me to point this out… maybe it's because my father always referred to himself as a writer, not as a craftsman or a woodworker.
DD
