Vicmarc 3-step jaws
Vicmarc 3-step jaws
Vicmarc 3-step jaws
Ted Evans
Do any of you use the Vicmarc 3-step dovetail jaws, and if so, what are the pros and cons compared to the standard dovetail jaws that come with the vm100 chuck? Thanks for your input and suggestions.
Re: Vicmarc 3-step jaws
If your talking about the flat dovetail jaws that fit 3 different sizes, then I have one, don't use it. It looked like a good idea at the time. I though it would fill some holes in my arsenal of jaws but apparently those holes don't exist because I've never even mounted it.
Alan Van art
I have the Nova equivalent to what you refer. If you are turning very narrow forms, like vases, or your bowls have long tenons, or I suppose it could be used on some spindle turnings. Mostly, however, I find that when you are trying to use the inner jaws, the outer jaws get in the way.
Jorge Casta�eda
Ted,
I have that set and did came handy when making stair parts. I think its for spindle work exclusively and there are some issues at the end of the spindle when using the 2 smaller ones if you are making a cylinder, no big deal, just flip it end for end and clean up. No problem with squared ends.
Ted Evans
Thanks for the info John and Alan, it was what I was looking for. So I ordered the VM100 with standard jaws. I have been using a Talon but after getting a VM120 last week, it became necessary to also get the 100. I use the Talon with the step jaws for smaller projects. Thanks again.
Ted Evans
Thanks for the info Jorge, I believe the standard jaws will work better for me.
