200+ woodworking book reviews
Bowl from a board
Bowl from a board
Bowl from a board
I have not done these in a very long time. Well if you don't count the dovetail one I did about 6 months ago. I thought this would be a good demo for our club because so many new guys don't have chainsaws, bandsaws or really anything but a lathe. I did this using the parting tool method of getting the rings.
I screwed up. You can see from the top view that I got the 2 top rings 180 degrees out. The repeated pattern should have gone all the way from the rim to the bottom. It's really hard to line everything up when all you have is the torn grain of the parting tool to look at. I Have 2 more flat blanks glued up. I'm going to make a large pencil mark across the blank to help light things up when I do the final glue up.
The two I'm working on now are flat glue ups instead of just one board like this one. Then I'll cut the rings out of these.
These go pretty fast as long as you start with a good flat board so you don't have to flatten the rings. I'm having fun. It's challenging because everything is pretty thin to begin with so vibration and controlling it is challenging. You could leave more wood by spacing your parting cuts further apart but then you would have fewer rings so your bowl would be smaller.
Re: Bowl from a board
Steve Kubien
Steve Kubien
Aside from the top two rings, I really like it. I've never done a BFB so I've got a few questions...
Regarding the parting tool method (which is what I would like to trying)...regular diamond profile tool?
Mounting: Do you start with the whole thing on a glue-block?
3/4" stock?
Thanks John!
I used 2 parting tools. One is thin parting tool made from a key hole saw blade. It's about a fat 1/6". The other one is a cheap HF mini parting tool that is about 1/8". I start the cut with the bigger one and finish with the smaller. Cuts down on having to make 2 kerfs to reduce the burning and I still get a thin kerf.
I made them before using my 3/16 parting tool you just have to take that into consideration when I do my drawing.
I draw them first and mark off all the lines so I make sure there is an overlap. I can calculate the parting tool angles at that time. Then I just lay this flat drawing on the tool rest and align the parting tool up with my drawing to get the angle. Takes all the guess work out of it.
For your first one just pick 45 degrees and space the cuts about 3/4 to 1" apart and you'll end up with a bowl. Doing it the way I did means there's little chance for error but you do get a bigger bowl out of the board. I used the drawing from Malcolm Tibbets book for this one. I normally draw my own, I was just too lazy to pull out the drafting board (remember those)
oops didn't answer all your questions.
I started with a glue block using 3/4" board. You could include the glue block in the base or not.
bob davis
i made these in 1995..before i learned about tree stuff from an article i WOOD magazine..two boards one walnut one maple. rings were cut on a scrool saw.
Looking good
I have used both the scroll saw and bandsaw to do these. May I use your photo to show my club. I won't have time to do a set like that before the meeting.
Re: Looking good
bob davis
anytime john
Guy Bratt
John as I picture the rings cut off on the lathe, I see the rings as captured between the headstock and the material. Do you break the rings? You must do thing else. Cut a couple then remove the material to retrieve the cut rings? That would be my plan.
I cut a ring off and it falls behind the chuck and spins around. I stop the lathe and hang it from the back of the chuck. The I cut another one off, same thing. After 2 or 3 I remove the chuck and remove the rings. Then I cut the rest. On this bowl the last 2 would not fall free because of the glue block so I left them until I stopped the lathe. I broke off the glue block. Of the wood was very fragile I would probably use one of the other methods of creating the rings.
When you use the bandsaw you are dealing with half rings so this isn't a problem. If you use the scroll saw you have whole rings and of course they do't all off either.
I'm missing something here.
Al Crandall
I've never made a bowl like this or tried your process so I may be missing something really obvious here but I'll ask anyway. Why don't you mirror your parting off angle about the spindle centerline? It looks to me like it would form the same rings but with the small diameters toward the tailstock and every one of them would just fall free of the lathe as soon as it was cut. When you finish the last ring you would find the glue block attached to the inside of the bowl bottom instead of the outside of the bottom but that is an easily corrected problem. Am I missing something, or is removing the chuck during the process, and futzing with loose rings while parting off others, just not a big enough deal to worry about?
Steve Kubien
Thanks Peter
Steve Kubien
I just bookmarked it.
Re: I'm missing something here.
bill crommett from Seneca
I'm glad that Al asked that question.
Mike Foster
Nice bowl John. Too bad you got the top rings flipped. Never tried this technique, but may have to give it a go just to see what it can do.
Mike
Al I will try that and see how it works. Don't know why I didn't think of it. I guess because my bandsaw table only tilts one way and I draw the lines on the top. It just seemed logical to do the same with this method. I will certainly try your method.
