Have a question? Ask Woody!
What do you use for Vacuum seals
I thought I'd start a new thread based on the one below. What do you all use for homemade vacuum chuck seals. I have used "0" rings. They work pretty well but the ones I had were pretty stiff. Consequently they didn't always seal well on bowls that got even a tiny bit out or round.
I purchased some "official" vacuum seal round tubing. It was about 3/8" in diameter and sealed really well in a wide variety of bowl shapes. However since it was so thick you could easily pull the bowl off center. Not enough to hurt for turning the bottom but if you wanted to add some decoration or a bead near the bottom you couldn't do it.
I've use the foam that you buy to stick your camper to the bed truck. Works pretty well although it's only 2" wide so you have to piece it together. I use clear silicone caulk to seal the joints. It's nice because you can wrap it around the edges of the chuck so you can hole narrow vases and stuff that won't even touch an O ring. It's downside is it wears out kind of fast. The good side is you have to buy a whole role so you have plenty for replacement.
Closed cell foam sheets from the craft stores. These work great. You can get them up to 11x14". They are about 1/8" thick and you can cut them any shape you want. They are stiff enough to compress evenly and you can wrap them around the edges so you can hold cones on the inside, vases on the outside and bowls and platters on the face. I glue it down with clear silicone caulk. If there's a downside it's the thickness. Since it doesn't compress much it won't hole bowls that are warped. You can get around this by cutting a square sheet larger than the chuck. put a hole in the center. Now place this over the chuck and put your bowl on there. The square corners make it easy to adjust to get it centered. The extra thickness compensates for warped bowls really well.
Anyone have anything else they use. I'm always looking for a better alternative.
Re: What do you use for Vacuum seals
closed cell craft foam- sticky back
Jeff Willaford
Lance Kanaby
I use Foamee found at Walmart and other stores. This is an 8.5" x 11" sheet with sticky stuff on one side.
James Fox
Finally...a question on Woodcentral that I have an answer for!!! Thank you John Lucas!
I use surgical tubing. Got it at local Borg--about 10 ft. in a roll. Outside dia. is about 3/8 in. & looks to be about 1/16 in thick. Made a straight line on outside, split it w/scissors, cut it carefully to fit over mouth of chuck made of PVC (trimming the ends so they will fit together takes some care), then super-glued it to the chuck. Takes a bit of tweeking to get the ends to match-up, and I suspect that silicone may be a better adheasive but haven't tried it. I've used it on several chuck sizes...small one is about 2 1/2 in dia., the larger with the bowl chucked in it is about 5 in. Works fine so far.
James
What a cool idea, thanks
Dave Gelnett
I use a closed foam shelving mat that I found at the hardware store. I can't remember if I got it in the kitchen area (for lining shelf) or the tool area (for lining tool box) but what I was watching for was a thickness between 2/16 and 3/16 closed foam mat. If less than 1/16 it was to firm and did not form well to the the wood surface. If to thick the bowl moved around as mentioned earlier.
In the picture it shows the glue I used which I bought from Sanding Glove for attaching Velcro but I think you can also get it from the hardware store. I cut out a solid circle from the foam and set the pipe with glue on just the pipe edge. Apply a weight and let sit for 20 minutes.
Next put the pipe and foam on the lathe and trim with a skew to leave about half inch on each side, now looks like donut. Add glue to inside and outside lip and apply clamps.
Cyril Griesbach
Sticky backed Foamies from Hobby Lobby.
Shoe Goo also works great as a glue
Doc Green
Almost any foam with a surface film will work. Doesn't have to be fancy. Lots of packing materials will work. My favorite is the foam used as underlayment for engineered hardwood floors. It is probably less than 1/8" thick. It's cheap, easy to cut, and a roll will last forever.
The chuck I use most often is simply a flat plate, made of MDF or plywood, up to about 14" in diameter. It is good for bowls having a flat rim. Keep in mind, however, that with a large bowl on a flat plate, the vacuum needs to be considerably reduced, to perhaps as low as 7 in Hg. ~Doc
Carol Reed, Strawberry, AZ
Closed cell weather stripping for doors and windows.
Chuck Engstrom
I tried a couple of sheet materials from MSC and I think the one I liked is their part number 31941735, page 1800 of Big Book if you're looking online. Adhesive-backed closed-cell white polyethylene 1/8 x 54", other thicknesses available. Several pages of similar stuff pages 1798 -- 1802. It's been some years since I tried it and in the meantime I've used other things, foam sheets from Michael's etc, with good success.
--Chuck
Russ Fairfield
I use the white packing foam sheets that are in almost every box these days. It is a closed cell, about 1/16" thickness, and it is free.
Ray - Middletown, IN
Paper towel sheet, it also works as a filter to keep any dust from being sucked into the pump. If the pieces is too out of round a piece of thin foam like that found in overhead garage door packing.
Ray
Jeff Brockett
I buy sheets of closed cell foam from Nashville Gasket. Most times they have odds and ends scraps that they will sell cheap. I trace out a large circle to fit the PVC pipe and use a sharp razor to cut the piece out - saving the inner scrap circle that is left to be used for a smaller vacuum chuck. Stuff works very well.
I use scrap neoprene rubber @ 1/32 thickness that gets glued and taped to the bell. Then a piece of plastic food wrap over that (with a hole, of course). Gives a tight seal and doesn't have much thickness to flex and leak. The food wrap improves the seal, and prevents any marks plus keeps dust/grit from getting embedded in the rubber.
jerry bennett
John, leather works great. It is easy to re-adjust the work as it does not cling like rubber products.
Thanks Jerry, I have some, will try it.
I bought some closed cell neoprene gasket material from an industrial gasket house locally. I got 1/8" and 1/4". the 1/4" is too thick for reasons you already know. The 1/8" stuff is great.
I also bought some rubberized sheet used for tool box liners and It is thin, maybe a 1/32". It works great for sealing flat hard surfaces such as between the faceplate nut and the shoulder on the lathe shaft. I made little washers out of it.
Jorge Casta�eda
I have the black neoprene seals that I got from packard, as they are black, if there is any slipping, they marr the work, so I add a piece of a white stuff used for packing, I think it is closed cell foam, on top of the neoprene, problem solved and as it got thicker, can adapt to some out of round or small irregularities. It has seen a lot of use and it's still there, when finally wears out, I have quite a bit of it around as it is free, I use contact cement to add and contact cemment solvent to remove.
