My new vacuum chuck for *LINK*
Rich Pearson in Mill creek, WA
my Jet 1236 Lathe. Fellow 1236 owners know that the hand wheels that exist have small male left hand threaded "stud" to attach it to the spindle. This creates a problem for mounting and dismounting a home-made vacuum chuck. Properly drilling out the small stud and still allowing for a draw bar or knock out bar is a very daunting task (for Beal or Don Pencil buffers) to secure a MT2 fixture.
I had been impressed with JT Turning Tools approach to hand wheels and vacuum adapters and contacted them to see about a custom hand wheel for my 1236. Tom Steyer was a pure joy to work with. He made a hand wheel for me which also accepts the JT Vacuum Adapter. The finish, fit and precision are great! The vacuum adapter runs smoothly without any drag.
I use a 10-20 piece of all-thread for both functions although the through hole is large enough to use a 3/16" drill rod for a knock out as well.
I have modified my 1236 to use a DC variable speed motor, however Tom engineered (and tested) the hand wheel to fit a stock 1236. Since it is now engineered, Jet 1236 hand wheels are available even if they do not show on the website yet.
The set-up looks great, functions great and Tom was easy to work with.
JT Turning tools delivers!
Thank you Tom!
top: photo of hand wheel and vacuum adapter in place:
Bottom: Vacuum hub with standard 2" x 4" plumbing fitting (foam seal yet to be added )
