Veritas - Innovation in Tools
Sticky quill Question
I have a Nova DVR about 8 years old. The quill in the tailstock has never been quit as slick and silky as I would like, but sometimes it gets stiff and sticky. I have taken it apart and cleaned the interior of the tailstock and the quill itself. I think the last time I did it I tried rubbing it with paraffin. That seemed OK for a while, but then the lathe sat for a while and it stiffened up.
So what is the best thing to lube the quill with? What is the best way to get it running smoothly.
Re: Sticky quill Question
Sean Troy
Teflon spray has always worked for me. I spray it on and spread around with a paper towel, let sit about ten min. and then wipe remaining off.
Re: Wheel bearing grease!
JamieDonaldson
I've just used WD-40 which I normally don't recommend it as a lubricant but it's always near my lathe so I used it and it's worked fine.
Bill Youngblood
On my Powermatic A, I've taken the quill apart and put in on another lathe running fairly slow and polished it with 600 paper. Be sure to wipe it clean after polishing. Also, hit the guide groove sides very lightly with a fine file. Be sure to keep the file flat against the sides and not take off the corners.
Mike Mills
Mike Mills
I use a product called Dry Lube (sold almost everywhere under various names). It is graphite suspended in a solvent. Just spray it on and when the solvent evaporates you have a slick dry surface.
Don't use it on the ways...been there....it was so slick I could not lock the banjo and had to clean it off.
For the tailstock or chucks it works great and does not collect dust.
Mike
my new favorite, Rust Reaper  *LINK*
Dick Coers
Rust Reaper
Terry Scott
Hi Barry we had this problem on a number of the Dvrs at our club
After checking the thread we found slight burs on bout the male and female thread
The male was run across a wire wheel and the internal a bottle brush type wire brush was used in a drill
Also take a file to the slot as you may find the the edges are burred with the locking bolt being wound in and out or the shaft twisting on the bolt when its not done up enough
Also check your tail stock is aligned with the head stock as this can cause the tailstock to flex and sometimes bend if it is fully extended
Use a lube that doesnt attract the dust
