Some river bush willow
Andrew Bourke
Hi All, some river bush willow (combretum species) that I turned over the last week. Let me know what you think! regards Andrew
Re: Some river bush willow
Joe Herrmann
Nice hollowforms--like the carving around the collar. The wood looks a little like our locust.
Joe
Ric Taylor
What Size Are They?
Ric Taylor
Dan Oliphant
The designs and execution are well done, good job. Is the yellow hue natural in this wood, and does it retain it?
Andrew Bourke
Hi, Thank you for all the reponses. The tall endgrain piece is about 8" and the crossgrain piece is about 6" in diameter. Regarding the colour, no finish has been applied as it changes to a greeny-yellow and I am therefore considering adding some colour. Any suggestions?
Regarding the wood itself, I have turned some locust here in South Africa and the locust has a much finer grain. The bush willow has quite a coarse grain by comparison but finishes well. Cheers, Andrew
Re: Andrew- for light fast pigments....
JamieDonaldson
...try acrylic paints or drawing inks rather than aniline dyes. They are cheap and readily available in a rainbow of colors. The pigments can be diluted with alcohol to the intensity you desire, but build color in layers rather than a heavy coating. They are water based, but water raises the grain, and if used in wet layers the colors will blend, so spend a bit of time with testing! Oh, don't forget the rubber gloves!
