A55 Smoothing Plane
Turning long straight taper legs
Keith Newton----Little Rock, Arkansas
I've been fooling around with making some small tables with long tapered legs. It is a very simple design, with a glass top. While I can turn the legs pretty fast, the sanding takes a bit longer than I like. And I never have entertained the notion of turning my shop into a production shop.
After searching for someone to supply them, I decided to check for earlier discussions, and don't turn up much there.
Does anybody know someone who would be interested in turning some 35" x 2.5" to .5" legs?
I would be interested in hearing what some of the turners here would charge for them. I am thinking that I might get back to turning some vessels which are dedicated or offered with the pedestal / table, so they don't have to find a place on an existing surface in a prospective clients home.
And of course, groups of three of differing heights, and diameter work better than individuals. I only mention that, as a suggestion to those of you that sell your work, to always try to display them in groups. Then whenever you sell one, to casually mention, or point out this aspect. I just sold a third to a customer earlier in the week, for a wedding anniversary. You know some men don't really like to have to think a whole lot about what to give on gift occasions. The power of suggestion helps with that trait. he he
Re: Turning long straight taper legs
You don't have to sand as much when you use a skew :D .
The charge for turning legs depends on a few things.
1) Complexity of the design - if there are bulbs, vases, etc. - they make turning more challenging.
2) Type of wood - if it is a more difficult wood to turn....
3) Who supplies the wood.
4) How quickly you need them.
Thanks JL
Did you turn all of those? Are they samples, or for a project?
As I think I stated above, I don't consider myself much of a spindle turner. Have you got any idea how long you spent turning any one of those in your photo?
Re: Thanks JL
Keith I you just need straight tapers do what my Dad does. By the way he's a really bad turner and his lathe sucks as well. He roughs out the blank to round. Then uses calipers to mark off the dimensions every 2". He cuts these to depth with the parting tool. He then roughs this out until there are just tiny bumps where each cut with the parting tool was made. Then he takes a belt sander with course paper and does the final shaping and clean up. After this he hand sands first with the lathe on and then with the lathe off with the grain.
I tried to get him to offset the foot so he could just rough it out in a straight line and forget all the parting tool cuts. Then he could use a block place to clean it up and true it up. He prefers his method.
I do the offset thing but do just a few parting tool cuts to fine tune the dimensions and then use a skew to clean everything up. With a good sharp skew I can usually start with 180 or 220 so sanding goes really fast.
Re: Thanks JL
Yes, I turned all of those. Those are for a couple of chairs and a settee.
The only time I do "samples" is when I'm experimenting or trying out different designs. I usually do samples out of soft maple - because I bought over a hundred turning blanks a few years ago.
A complicated turning (baluster style) might take me an hour or so when I first start. Figure on another 5-10 minutes of sanding. A simpler turning takes less time. As that style gets into your "muscle memory" - you get faster.
Right now I'm experimenting with some spindle designs for a cradle that I'm making. I've got about 24 spindles to turn. The sister-in-law of the expectant mother wants a modified New England baluster - I've got to get it short enough to fit the sides.
