Barracuda 2 Titanium coated Chuck
Peter Charles Fagg (UK)
Friends, recenly Woodturning magazine (UK) showed a new product from Penn State Industries called the Barracuda 2 chuck.
It interests me as an addition to my lathe and I would appreciate experiences good or bad about the same?
Regards, Peter.
Re: Barracuda 2 Titanium coated Chuck
Ken Vaughan
Ken Vaughan
I have two of them -- one was acquired for a 3/4 by 16 lathe and the other is for a Jet 1014VS in Snobird land (Arizona in the winter).
They are decent scroll chucks that are well suited for 1 by 8 chucks as that is the native threading. They come with a 3/4 by 16 insert.
The machining is not a smooth as more expensive chucks, but they do a good job. Measured runout has been 0.005 to 0.010 inches.
If you have something bigger than a Midi lathe (say 12 inch) I would go with the onway/nova/vicmark as they have better fit and snug up on a tenon with a bit better confidence. And yes, I have one of each of those also.
I keep the one here in Alaska to take to Tongass Turners meetings were we have midi lathes to work with.
Ken,
Thankyou for your response.
What I would really like to know is whether the Titanium coating is only for show or is it of some value, possibly against rust or contamination when turning Green Oak?
Perhaps the chuck could be cheaper but just as serviceable without the coating?
Regards, Peter.
Ken Vaughan
Durability of Barracuda 2 Titanium coated Chuck
Ken Vaughan
I went out and looked at chuck jaws -- VicMark and Talon are black steel. Super nova has large jaws on it and they are still bright silver. Barracuda has plated jaws.
I do not have green oak here in the northlands, so miss the tannic acids --
I expect the ti platings are very hard, but thin. They probably will hold up a bit better than black coated steel, but there is a lot of steel in a set of jaws. The Barracuda are not a well machined as the others, but seem adequate for most purposes. Fiiner machining vs price is the tradeoff.
Decent chuck, but not the same finish and tolerances as the more expensive ones.
