the chain, the chain...
GaryG in MD
To put it simply, my chain saw is not cutting well.
By that, I mean that it is very slow to cut.
This is an electric 16" with what I believe to be a "safety chain".
I know it doesn't cut like a gas job, but it has done fine in the past for what I need.
By "safety", I mean that there are two long, flat-topped links between each cutter. These links are at the same height as the rakers.
When I cut cross grain, I get nice chips, but it goes very slowly and takes too much pressure to move through the wood.
When I rip, I get nice long "straw", but it goes very slowly and takes too much pressure to move through the wood.
I do not get powder in either case. I take all this mean that the cutters are reasonably sharp and properly shaped. So why don't they cut more quickly?
I have sharpened this chain successfully a number of times in the past. The cutters are down to about half their original length.
I recently lowered the rakers and the safety links (twice, as a result of this problem) to a cutting height of about 1 mm. This is almost twice the recommended cutting height. It still won't cut.
I have two more new chains that I could put on, but I want to understand why this chain won't cut, because if I don't, I'm sure (says Murphy) that it will happen again in the future with the next chain.
So what's wrong???
TIA, Gary
Re: the chain, the chain...
A picture would be worth many words; preferably a full side profile and 3/4. Yes, Mr. Mill, we are ready for your closeup. ;)
How are you sharpening your chain?
GaryG in MD
Good idea, Mark. But I'm not going to be able to do it for about a week... ...GG
Jorge Casta�eda
Gary,
It sounds like the wrong chain for a man with lots of cutting, maybe is one of those made to trim small stuff.
When a chain starts to cut slower than it should, it means that the rakers are higher than the cutters, need to be filed down to slightly less than the cutters.
garyg in md
Jorge, The simple answer is just a new chain -- I have two, but hoped to use this as a learning experience. The chain still has life in it and I SHOULD be able to make it work again. It has worked fine in past years (I only have around 6 cutting hours on it). The rakers are definitely below the cutters -- perhaps even a bit too far, as are the safety links. Still cuts slowly but with proper chips and straw. Will have to do some more research on this. In the meanwhile, I'm just going to put on a new chain. ...Gary
