Initiated into Bottle Stoppers
Barb Siddiqui
I needed some quick birthday presents, so put the mini lathe to work for my first bottle stoppers. More difficult than I expected, because working in miniature does not leave much room to correct mistakes! Fun to make, though. From left to right, they are plum, silver maple, orchard cherry and apricot, with an oil finish and buffed.
I don't know if it is visible in the photo, but the one on the right has a clever pattern of incised arrows or long triangles in two rings around the neck of it. That was a design opportunity. I failed to drill the hole deep enough for the thread cutter, and after turning it in with force, I was unable to remove the finished stopper from the threading mandrel afterward. Being very upset at not being able to detach it, I tried all sorts of padded grips to hold it for vise-turning; no-go. I had buffed it quite nicely, and nothing would hold it but (ugh) vise-grips. Resigning myself to ruining the stopper, I grabbed hold of it and finally unscrewed the threaded mandrel. It was obviously marked by the teeth of the vise grips, and thus ruined. Then, 'hey, wait a minute,' hit me, and I simply re-applied the vise grips to the neck of the stopper all the way around as if patterning it intentionally.
So, if any of you want a nice pattern of inverted triangles on a small-necked object, now you know how to apply one.
