new hunter tools
new hunter tools
new hunter tools
Do you remember the hollow vessel I blew up? Mike Hunter said he had the right tools to do the job. I now have a set. They are 3/8" shaft with a Hunter #1 tip. One is called a back tool. It's the top left tool. This is for hollowing under a lip. The cutter is angled back.
The second tool is called a hook tool. The cutter is flatter. In the 3 shots in the middle you can see that it will hollow some of the bottom and all the way up to where the back tool stops.
The last tool is a straight tool. In these photos I show 2 ways of cleaning up the bottom. One is with the tool pointing to your left. The other is pointing to the right. I use the right pointing direction to clean up the center nub on my hollow vessels and vases.
The bottom shot is a group of the tools. Mike also sells a handle adaptor that fits in schedule 40PVC pipe. I turned an aluminum bottom to match the adaptor and then made the handle.
Can't wait to try them out. It will probably be later in the week after I finish the projects on the books right now.
Re: new hunter tools
GaryG in MD
I saw these in use in Hartford by Mark St. Leger -- he had a hand in the design -- they work great. I really "need" that little "back hook" -- I feel it calling to me. ...Gary
Dick Hines
Dick Hines
I was Mark do a demo last Tuesday and tools worked great. I could not figure out the handle he was useing. Does Mike have them for sale?
Mike Stafford
Mike Stafford
I have a set of these and I love them for smaller boxes and orts bowls.
They take some getting use to because the smaller cutter will self feed in a New York minute. Once you get the hang of them the only problem I see is that they cut so effortlessly you might have the inside diameter meet the outside diameter.
I love the tapered end and the stronger shaft providing reach support.
Greg Haugen
I have a set of these as well. They've become my "go-to" tools for ornaments, small hollow forms, and small boxes or detail/finish work on larger pieces. The tool shapes along with the angle of the cutters are an excellent combination. Mike Hunter and Mark St. Leger did an excellent job with these tools.
Greg
Rob Wallace
Tell Mike he needs a new name.....
Rob Wallace
......for his "hook tool" that you show in the second row of images.
The woodturning world already has a well-known and very long-standing kind of turning tool by the name "hook tool", and many woodturners already know what this tool is and how it works. While Mike Hunter may have produced an efficient curved shank hollower using a carbide insert, he has not produced a new hook tool! Calling it as such doesn't make it one, and trying to establish this name for his tool will only serve to introduce unnecessary confusion if it is marketed and sold as a "hook tool".
Several years ago there was an effort to try to standardize the naming of woodturning tools which apparently did not go very far. For example, the named sizing of gouges by either flute width or metal size is a common disparity of tool nomenclature between manufacturers cited in an article in American Woodturner a while back. It would be good to have a common nomenclature for all turning tools, but I suppose it is difficult to get there.
I am a botanist that specializes in the naming and classification of plants, and I am sure my colleague Andi Wolfe would agree with me in that the names of things that we communicate about are important, whether they are plants, animals, or turning tools. I think that the same principles of selecting non-confusing and descriptive monikers for the items we name and use should apply to the naming of our woodturning tools. Names that have been used already (and whose names are already well-established and are unambiguous) should be avoided if possible (e.g. there is already a concept of what hook tools are), particularly when they represent a substantially different kind of tool than the one that requires a new name.
If the name for a new tool is not going to be descriptive, it should at least be unique. Recent examples are the "Easyrougher", the "Elbo Tool", the "Scorpion", the "Gage'T", or the "Vortex" tool. Most reasonably well-read or experienced turners know what these tools are, and their names are not confusing. Not so for the established hook tool and the "new Hook Tool" shown by John.
I agree with Mike's names of "straight" tool and a "back tool" as these are descriptive of their structure or function. However, the name 'hook tool' already exists and represents a distinctively different tool; we don't need to introduce future confusion with the names chosen for new tools!
Can we please be creative and develop a different name for the tool represented in the second row of John's images, and keep a hook tool a hook tool?
Rob Wallace
How about -
Side cutting carbide solid ring tool. In reality there are several hollowing tools that curve and are called Hook tools. John Jordan's curved tools are called Hook tools. Perhaps we should call what we call a hook tool, a hook cutter. That's more descriptive. Of course it would have to be in latin. Ringus cuttus in hook shank.
Mike Stafford
Re: Tell Mike he needs a new name.....
Mike Stafford
I think Mike calls them Hunter #1 swan neck tools. I do not recall how he differentiates between the swan neck with canted cutter and the one with the cutter mounted at 90 degrees to the shaft. I will find out.
I am sure he is glad that there is someone concerned about the etymology of the name....
They remind me of worms!
Carole Valentine
The cutter is the mouth and they even look like they have tiny little wrinkles on the shank like those on the bodies of some sea worms! Maybe he should call them Hunter Worms.
