Dealing with critters in the wood
Fred Holder
Hello All,
A reader of my book, The Woodturner's FAQ, just asked me a question that I can't answer because I've never had the problem. Here is is question:
"When I find a dead tree and cut sections for future projects I find that the wood is full of ants, termites and other unknown bugs. What do I need to do to prior to storing this wood in or beside my work room? I don�t want to introduce termites into my work room/garage."
I guess I've been fortunate and never encountered this problem. Can you guys help me help my reader?
Re: Dealing with critters in the wood
Janet Bequeaith
How about stashing in a freezer for 10 or 15 days? Or microwave one (1) minute at a time for several minutes. Think I saw this idea in a magazine--not tried it.
fgvanatta
I've used both the freezer and microwave solutions. Both work, but they limit the size of the wood you can work with.
Try putting them in heavy duty plastic bags with moth balls added.
Frank
Russ Fairfield
Bugs in green wood were a common problem when I lived in North Florida. Other than Powder Post Beetles there was rarely a problem with bugs in dry wood with no bark. Kiln dried wood was rarely a problem, but air dried wood was always a problem.
Sometimes leaving the bugs to do their work was an advantage because of the hole patterns they left behind. Left to themselves, they will eat their way through the wood, and leave when they are finished and as the wood dries. I always saved some of the "holey wood" because it can be an attractive pattern in the wood.
What I did to kill bugs was remove the bark off of the wood, cut the log in half, stack with something to separate the pieces of wood from each other and off of the ground. Then I covered it with a sheet of plastic, put weights around the stack to seal the plastic cover with the ground. Depending on the size of the stack, I set of 1 or 2 bug bombs under the cover and left it for a week. If that didn't kill all of the bugs, I either separated the bugs so they could do their work on the wood without getting into everything else, or hauled the wood to the county dump.
The reason for removing the bark was that unless I was going to turn a piece of wood immediately with the bark on it, there would be an new infestation of bugs under the bark within a year no matter where and how I stored it.
Re:There are as many folktales .....
JamieDonaldson
...about eliminating bugs as there are species of wood. The only method that I attempt is moth balls in a plastic bag. I can't imaging freezing has any significant effect on most bugs because Ma Nature does that process every winter without significant losses in most bug infestations.
Mike Stafford
Mike Stafford
If the insects are actually in the wood I do not know of a treatment that will penetrate effectively. Freezing will cause the adults to die if you can get it cold enough but larvae will survive unless you can get it extremely cold.
One of the most effective ways to kill insects is heat. If you can uniformly heat the affected material to at least 180 degrees that will kill all the insects. Heat is used in a variety of industries just for that purpose.
It might be possible to bag the wood in heavy plastic bags and fill the bag with pyrethrin which might or might not penetrate to where the insects are living and kill them. Pyrethrin is a safe organically derived insecticide which is processed from chrysanthemum seeds. It is not persistent and breaks down readily with exposure to air so it will not last long. It is the only insecticide I use in my garden.
Dry Ice
is one method that has worked for me. I put a hunk of dry ice in a plastic bag with the wood. The dry ice sublimates into gaseous carbon dioxide (not really recommended for indoors) and displaces the oxygen in the air. I leave the bag sit for a day or two. You have to vent the bag a little (like leaving it loosely tied). I suppose you could do the same with a garbage can. I've also used the bug bombs in a plastic bag - that also works.
Of the two, I prefer dry ice. It's odorless, it isn't "persistent" and won't leave a residue in the wood. It is less toxic to me in the long run.
Fred Holder
Thanks All,
I'll send along all of the answers to my questioner.
Fred Holder
Lets not make the problem bigger than it is
Keith Newton----Little Rock, Arkansas
First, Carpenter Ants don't eat wood. They do chew out tunnels for their nest, but once you cut the wood up into lengths, they will probably leave anyway.
If you or your builder had any sense, you would have treated the ground under your foundation for termites, which eliminates that worry.
You can knock the bark off, but the sapwood will dry faster than the heartwood under, and will check, which is ideal for other insects to lay eggs in.
Or you can leave the bark on, with rot and insect resistant woods, and let them have their way for a couple of years out in the weather, and eventually, you have all heartwood, with a nice weather texture for a natural edge. Just leave the log parts as long as you can deal with, in the shade, and I leave mine in ground contact. Here in Arkansas, we get enough rain to keep the heartwood green if the ends are kept painted. Some don't even need that.
Turn green. Let it change and do its thing. Get over it if you don't like that it is not round. It is wood, what is the problem with that?
Allen Neighbors
I don't know the name of the critters that bore into wood around NW Texas. But if I ever have leftover wood in my firewood pile, it is summarily dispatched after the winter is over. When spring arrives the larvae hatch and the bugs fly back to the wood pile and deposit more eggs into the bark, which become larvae. The wood becomes very lightweight, and the sawdust pile underneath grows tall.
I kill them by drenching the wood (after turning) with Lacquer Thinner, or injecting the thinner into the holes with a syringe. Both ways usually work.
There's not much danger of getting this type of bug into the wood in your shop or house, if it is bark free. They won't lay their eggs in bare wood... just bark.
Now, like I said, I don't know the type of bugs we have here. The one that gets into the Mesquite and most other wood around here, are very fast, and flighty, and are black with white spots, and are about the size, and remind me, of a mud dauber.
