I'm still trying to find the best recipe for cupcake icing. Here is a photo of the latest test. The top left one has the best icing look but the epoxy filler is tan so it really changes the color and I doubt you can get light pastels or whites which unfortunately is how most cup cake icings look.
To be a good candidate it has to hold a sharp edge, take color well and have a texture that resembles icing which is kind of sugary. To make these as lidded boxes it also has to be tough which rules out many of the nicer looking formulas I've tried.
The bottom left may be the best choice so far. It is a white filler that is so fine you must wear a mask to mix it because it floats in the air. It's hard to mix but doesn't change the color of the paint that I'm using and seems to hold a crisp edge. I'll mix some up later this week and use the icing decorator tips to try it out.
You can see two of the latest cupcakes in the back ground.
Another idea you might mess with is Plastic Resin. You can get it in a clear formula that you can mix, dye etc to whatever you need. Ed Davidson might be able to weigh in on his thoughts on if that would work for this application.
Randy I've played with Resins of different types including fiberglass. The basic problem is the filler that you have to add to get it to an icing thickness. Most Resins and epoxies are too glossy looking. Adding the fillers not only changes the gloss but also thickens them. That's why I'm playing with different fillers because I need a certain texture as well as thickness to achieve the final results.
Charlie I think micro balloons are what is in the filler I used on the bottom left sample. The top right sample is a gel medium similar to Golden's. It looks perfect and spreads just like icing but it simply doesn't get hard enough.
You didn't say if you have tried good old Bondo auto body repair compound. I helped my son make a mountain & volcano with it this past school year, and it seemed like frosting to me! I air brushed the color onto the Bondo for his project, but you might be able to add colored pigments to it (..maybe dry tempra paint?) while you mix the filler and hardener to get the frosting color you want. Once it's cured, it has most of the properties you are looking for....alternatively, you could paint/air-brush the finished icing to the color you want using opaque paints.
Just a thought - you may have already been down the Bondo path already...??
I did play with Bondo. It comes as gray or red and it's hard to mix any color with it. I did think about using "whatever" and then air brushing but I would have to mask off all the areas outside the icing and that would be a real pain. I'm trying to keep the cost down on these things because I know the won't sell if I get to expensive.
They make a thin version of bondo called metal glaze. If you mix the catalyst rather light, it will take longer to dry and will flow out to a nice shine. The stuff we use here in the model shop comes in a nice pale blue color, and a dark blue glaze
Perhaps you could bake it - at a lower temperature - say 150 - to get it to harden - or WAIT a few days.
Maybe a lot of thin layers, dried for an hour or two between applications would set up faster in the long run.
The other possibility is to just go with the Dipped Icing look.
Or you could use the formula in the upper left - epoxy filler - then airbrush with white primer to get it lighter, then airbrush whatever color you want.
Ain't the pursuit of Wild Hare Ideas fun? And with all this experimenting, you'll probably find something you don't need NOW - but may be perfect for a future piece. If nothing else, you're narrowing down the possibiliities that DON'T Work - to paraphrase Thomas Edison.
Durhams is the green one on the bottom right. I've been using it but any sharp edges are fragile and it's tan so it's hard to get light pastels or whites.
I'll have to try that. Does it get very hard? Of course your asking someone who can barely cook in the microwave to mix these chemicals together. With my luck I'll create a bomb and be on the terrorist watch list, or dead.
My mom made the play dough 40 years ago, crafted clusters of grapes with vines and all, they are still hanging on her wall.
She slow baked in oven and after painting some highlights, she sealed everything with deluted white glue. What about using spray shellac or thin epoxy to coat icing?
