twine holder and cutter
woodenleg
I need to make a twine holder for the people who make sausage for me. I have made cutting boards for them in the past. The ones that I have seen online look to be tapered, my friends tell me that the twine comes in tapered and non tapered. any suggestions of what kind of wood and what I could use for a cutter?
Thanks in advance. Dave
Ps. I have been using a stool for turning a the lathe as was suggested by someone here. Thanks again
Re: twine holder and cutter
Cutter
Al Kapocius
Been pondering this'un for a few years. Allus thot about making the cutter out of a short length of hacksaw blade, cuppla holes drilled or punched for mounting with screws and the saw teeth ground off.
For real fancy cutter, drill another couple of holes to break and bend out a short section so the twine on the skein end is captured instead of flapping loose after cutting.
Al Kapocius
Re: Cutter
Kinda what I thought, except, Can you drill a hole in a hacksaw blade? I thought they were harder than a regular drill bit. I have been waiting for an excuse to try this trick. Take a steel rod and chuck it in the drill press and put the end of it on the blade where you want the hole and run it against the blade until you burn the spot. Then you can drill trough that spot with an ordinary drill bit. Give it a try and let me know if it works. I would do it myself; if I had a steel rod, if I had a hacksaw blade, if I had a drill bit I did not mind trashing.
Jim H
I made something very similar onetime. I made a block of wood with a slot to pull the string into from the side. That slot intersected another slot from the back that held a �exacto� blade. I wish I could describe it better, but hopefully you get the idea.
Doug Turner
How about one of those letter openers with a recessed razor blade that is given away at all the trade shows. They have a plastic body that is easily drilled for mounting.
Re: Cutter
Tony - Memphis
The blades I have used for various other tasks are only hard around the teeth. Not sure if they are all liek that but they probably are. Otherwise, they would probbaly be too brittle.
Tony
Re: Cutter
Don Evans
Barry, Tony is right. Look for the term 'Bi-Metal' on the hacksaw blade. Meaning it is made of 2 different types of metal. The blade is made of hardened metal that the teeth are cut into (prior to hardening) and it is welded to the main part of the blade. These are usually painted blades so you cannot see the joint. The joint will be just barely above the teeth.
To remove the teeth you would have to grind them off but the rest of the blade is fairly easy to cut, bend, drill, etc.
Don
Re: I made a string cutter something....
JamieDonaldson
...like what Jim described, but used a blade section from a utility knife, which had a slot already made. The knives with replaceable blades that break off a section for a new tip are cheap and readily available.
