Beads! Little Tiny Glass Beads!
charlie belden
I first knowingly encountered little tiny glass beads while working on a survey crew - "cat tracking" dots for lane lines a painting machine would paint later. We were done for the day and were packing up the truck when the painting machine showed up.
I'd always been curious about how they got painted lane lines to shine in my headlights - so I figured the guys who did the painting might know. Turns out one of them did know - and explained why they shine some of your head lights light back at you - beads - little tiny glass beads - dusted on the freshly painted lane line. Transparent sphere have this neat ability to have light that hits them - shine back at where they came from. And the guy gave me a couple of table spoons worth of some of those little tiny glass beads - actaully - spheres. That weekend I did an airbrushed painting - a cherry branch with new buds about to open - a sun rising behind it. The little branches were just silouhetes - and they needed "something". What they needed was some sparkling dew on the bottoms - where dew forms - and then glows when back lit - or front lit.
I'd been doing some work with acrylic pieces so I had a glass syrince and a small hypodermic needle for applycing the acrylic "glue". Also had some thinned down rubber cement I'd used for masking areas while air brushing. Fine line of rubber cement - PLUS - a little sprinkling of little tiny glass beads into the still wet cement - bingo - glistening dew! (when the light hit it right).
So the next time I saw the striping crew I asked where I could buy some of those little tiny glass beads/spheres. "You can only get it in hundred pound bags - and you have to order 5 bags minimum."
Well #*^&%$#@#$ !
This morning, while helping a turning club member get rid of a bunch of stuff before he moves back to Tennessee (sp?) - in addition to a bunch of wood - he asked if I wanted a gallon container of sand blasting beads ("bead blasting").
Glass Beads!? Are they little tiny glass beads?
They were - and now I've got about 3 quarts worth - a fellow turning club member took about a quart to play with.
So I'm thinking - a little lacquer - with some retarded added to keep it sticky for long enough to sprinkle on some LTGB (Little Tiny Glass Beads) - followed once things have dried - with a high gloss thinned lacquer spray - might make for an interesting looking surface.
Anyone played with LTGB? If so, got any tips to share?
Re: Beads! Little Tiny Glass Beads!
Be carefull Charlie!
Scott Burr in Ben Lomond CA
If they are truly the glass beads for bead blasting, please be careful. They are highly carcinogenic when breathed. Take precautions when working with them. Nothing like filling your lungs with tiny glass slivers...
karl jr
Re: Be carefull Charlie!
karl jr
This reply is a perfect display of the knowledge base that exists on this board. It's what keeps me coming back. Solid know-how and creativity, with a good measure of safety-speak. And no politics!
Re: Beads! Little Tiny Glass Beads! *LINK*
Mark Wollschlager
I had thought to do the same a couple of years ago after picking up a handful of the beads from the street.
I found them for sale at a Pearl Art supply store in a 1 lb. can.
Don't recall how much they were, less than $20 I am sure.
Still haven't used them though.
I was going to mix them with black gesso for the inside of a open hollow form.
Anyhow, hope this helps.
Mark.
Rolco labs reflective bead description
One more thing...
Acrylic "glue":
Is generally MEK= methyl ethel keytone.
One of the most nastiest things man has put on this planet sense the beginning of oil refinering . After all the chemical companies don't give a Rat's a**! in what it does to our mother earth. They care less about us, we're replaceable :|
That Which Does Not Kill Us - Makes Us Strong?
charlie belden
Growing up in Central America, the former Panama Canal Zone, I was exposed to just about every bug, mildew and mold only the tropics can support, and, if it wasn't raining a LOT, I and most of the kids in the neighborhood ran behind the DDT truck that "fogged" the area with DDT once a week. We swam in rivers and played in ponds that surely harbored a myriad of microbial life just looking for a host - and usually drank some of that same water. We ate meat of questionable origin, off a charcoal or wood half 55 gallon drum barbecue and made and ate ceviche of fish we caught in and around the throat of the Canal on the Pacific Side (the other side of the Canal being referred to of course as The Other Side). We stood in the middle of a field, garbage can lid "shield" in hand - and shot arrows straight up in the air - as high as we could shoot them. We had BB gun wars and climbed out to the very ends of branches 25 to 30 feet off the ground to get THAT mango - that one or more avian creatures had probably contacted directly - or "indirectly" - and ate THAT mango as soon as we had it in hand. We inner tubed down rivers in flash floods, stuck our leather gloved hand into holes thirty feet underwater hoping to grab a lobster and often found ourselves in the middle of a lake during a lightning storm - the likes of which you only get here in the "States" in and around central Texas. The ones of us who died - did so usually on a motor bike - at 3 am, going 80 miles an hour - with a half bottle of rum under the belt. I lived down the hill from the Middle American Research Unit (MARU), where they worked with all sorts of tropical diseases - and experimented on goats and sheep - we used to feed and play with - unbeknownst to the staff of MARU. Most 10 year olds owned - and knew how to use - a machete - and we used them to make "forts" in the jungle. We had monkeys and parrots and snakes and lizards and even bats as pets. We regularly had contact with people from all over the world and from all walks of life.
Other than infrequent bouts with re-occuring malaria - thanks to skin and scuba diving in the San Blas Islands off the Atlantic coast of Panama, I'll put my health record up against any of my contemporaries and I'll bet I've been sick fewer times and only been hospitalized ONCE - for a herniated disk - acquired by sitting in a horrible chair while working at a computer terminal for 10 hours a day, 6 days a week for about 5 months.
BUT - I AM going to be very careful working with these LTGB because - at 64 - is time to stop Tempting Fate. And as been rightfully noted - someone here will always point that out - and probably save me, or someone else some grief. Thanks Scott.
charlie belden
Thanks for the link to another source.
I wonder if MicroBallons that model airplane building use as very light filler would reflect light as well?
Jim DeLaney, Austintown, Ohio
Re: That Which Does Not Kill Us - Makes Us Strong?
While perhaps not quite as daring or colorful as yours, Charlie, my earlier years were peppered with many similar experiences.
Here I am - 65 years old - in pretty good health overall, and in "pretty good shape for the shape I'm in." ;-)
Gotta wonder if some of today's generation of coddled youth will ever be able to say the same?
One thing they won't have, though, is all the 'interesting' life experiences folks like us have enjoyed (or endured)!
Jim D.
Barry L Elder
A little knowledge can be a dangerous thing. (paraphrased)
Dave Long
If you want to see how glass beads and segmented turning can work together go the website www.kazistudio.com. Marilyn Endres from the Austin, Texas and Eucled Moore, who lives in San Miguel Allende, Mexico put out some of incredible work. Marilyn sets antique glass beads into the segmented work one bead at a time. A lot of their work has over 50,000 beads in the pattern.
spectacular link
matt overton
