turning basswood
turning basswood
Steve Kubien
turning basswood
Steve Kubien
Hey folks,
So I got a couple of small logs of basswood. I know carvers like it when dry. Any good as a functional bowl-wood at the table? Too soft? I'll probably texture a couple and do some burning but do these have a long future in regular use?
Thanks!
Steve
Re: turning basswood
IMO, basswood makes nice "decorations". if you don't have to touch it or use it (i.e. just look at it) - it works fine.
It is so soft, you can easily dent it with a fingernail. I've got about 70 board feet of 6/4. It carves quite nicely. Makes great decorative panels.
Dave Belser
When turning, the end grain tears very easily. It's only a slight bit better than fir in this regard. You could turn it to practice your tool usage on end grain!
I use the stuff I have almost entirely for jam holding of work. The softness allows it to give instead of the piece you are working on. As others have said it often used for carving.
- Dave
Steven Antonucci
Carve it!  Carve it!  Carve it!
steven antonucci
C'mon everyone! Chant with me...Carve it!
good stuff to carve, I have turned it once or twice before, but either as a jam chuck or an egg that I then carved anyway...
Good carving skills reinforce good turning skills...rub that bevel!
S
Carole Valentine
Steve,
The stuff I have turned and carved was known as Lime which is supposedly the European name for Basswood. I found it wonderful to both turn and carve. Could be the locally grown variety is softer...don't know.
Malcolm Ray
We have basswood in Maine,its a bit on the soft side.....I've found that the wood from the Michigan,Wisconsin area holds detail better as its a bit more dense.......it all carves well.................
Steve Kubien
Thanks folks
Steve Kubien
I suspected it was too soft for regular use. I'm not a carver by any use of the term but maybe I'll rough a few bowls for future experimentation. Decent jamb-chuck material is always welcome as well, especially since I do not have a vacuum chuck and I find a doughnut chuck too bothersome most of the time.
What's it like to dry? Does it split as you look at it like apple or is it fairly forgiving?
Cyril Griesbach
Steve,
You're a member of WoW so if you'll go to my album there you'll see a photo titled "Experiment". This is Basswood, also known as Linden.
I've turned a number of items from Basswood and have used it in demos as it turns and sands quickly allowing a project to be done within time limits that may not be accomplished with harder woods. While I, like most others, don't believe sanding should be included in demos, using Basswood allows lightly sanding a demo project so it can be given to the group attending the demo.
Additionally, Basswood can be a good choice for a "proof of concept" when beginning project you've not attempted before.
Cyril
Steve Kubien
Steve Kubien
On my way over to WoW in just a moment. Thanks for the map. Originally I had hoped to make a set of bowls for daily use but I figured, and the answers here confirmed what I thought, it would be too soft. Yup, lots of experiments and jamb-chucks and useful stuff...just not the use I had hoped.
Cheers,
Steve
Fog Tanner
I had always wondered what turning Balsa wood would be like, after having turned some Bassword I no longer have that desire. It is light and harder/denser than some of the Balsa I have (the 14lb and 22lb Balsa is harder/denser). I do use quite a bit of it in my building models for certain stress areas.
I have turned a number of small bowls from it and the only problem I had was it flexed when you got it thin.
These were offcenter pieces and it was like turning a single bladed fan. I do use it for some art projects where I am looking at saving weight in some areas. It didn't cut cleanly at times but it sands easily. I have used both shellac and epoxy as finishes with good results.
Fog
Walt Bennett
Walt Bennett
I've not turned it myself, but I make hat blocks with a Vicmarc VOD out of yellow poplar for my wife and for sale, and in the past many of these were made of basswood. Since a hat block is solid, even if it was basswood there wouldn't be a problem. Most of the ones I make are for ladies hat makers, so they stick pins into them to hold the hat blanks while drying and basswood will start to fall apart after a bit. I'd suggest that you follow the 'carve it' recommendation someone else made.
karl jr
VOD?
karl jr
I'm sure that doesn't denote video on demand.
Walt Bennett
Re: VOD?
Walt Bennett
VOD = Vicmarc Ovalturning Device (http://www.vicmarc.com/default.asp?contentID=549)
