A couple of days ago I posted a question regarding beeswax-based salad bowl finish as a way of finishing salad and fruit bowls, which I tried for the 1st time the other day in place of the General Finishes finish that I had used before. There was a discussion of whether salad bowls should be shiny or not, but the question I still have is about something else: how to properly apply the beeswax finish. The instructions on the can say that all I need to do is apply it with my finger and let it dry. But after drying it for days I still have a thin wax film that leaves residue on my finger when I touch it. I don't want the same thing happen to the food that goes into the bowl. I suspect that if I warm it, it will melt and penetrate the pores. But then what? Is the finish going to "bleed" out of the pores later? How do I make sure it does not happen? Also, if I do want to melt it, and I do not want to apply the finish on the lathe, can I apply it with my finger and then microwave the bowl on a low setting? Thanks much!
Re: Confused about beeswax-based salad bowl finish
Skip Beardsley
suggest you look at Russ Fairfield's web site. He has more about finishes, and wax in particular, than you will ever need to know. I know he considers the was finish to be inappropriately applied if you can feel the finish.
Skip
