Ok I know there has been a lot on lacquer finishes but my question has to do with how to spray it on. I have been using a spray can for the past several years but I think that can get expensive compared to spraying the finish on with a HVLP gun. Is this true?
If I do try to use a sprayer should I thin the lacquer? I would think if I needed to use the lacquer as a sealer it would be best to thin the lacquer?
Final question; this sounds like a pain to get the sprayer ready, shoot a few coats of lacquer then clean the sprayer. I normally only do one bowl at a time. Wait some period of time and start over. Is there a way to leave the lacquer in the gun for a day or two while adding coats of finish to my bowl?
QUESTION: I have been using a spray can for the past several years but I think that can get expensive compared to spraying the finish on with a HVLP gun. Is this true?
ANSWER: That depends on how much you spray and how often, and whether you have to buy the gun and compressor. HVLP can get expensive. I use a plain pressure spray gun from Harbor Freight that now sells for about $20 and a portable air compressor. That will be the cheapest way to go if you already have the air ompressor. Refer to my website for instructions.
QUESTION: If I do try to use a sprayer should I thin the lacquer? I would think if I needed to use the lacquer as a sealer it would be best to thin the lacquer?
ANSWER: How much thinner is used will depend on the spray gun. I use a 50/50 mixture of lacquer and thinner in the HF gun.
QUESTION:
Final question; Is there a way to leave the lacquer in the gun for a day or two while adding coats of finish to my bowl?
ANSWER: There is no need to empty and clean the gun between coats, or between pieces to be sprayed unless the time between uses is severl months. The only problem can be that the thinner can evaporate if there is an opening in the gun, or the lacquer turns color with age. I spray 3 coats at a time for 10 times over a period of 10 to 20 days for a lacquer finish with no problems. I have also left the gun filled with lacquer for 3 to 6 months between uses, and the most I have had to do was dip the tip of the gun in some lacquer thinner to clean the dried lacquer out of the end so it will spray.
Again, reading the text on my website should answer all of your questions.
Preval makes a real nice "spray gun" system for just the circomstance you are concerned about (spraying one project). The unit is a glass jar (holds about 6 oz.) and a power unit. The power unit uses Propane, Isobutane, and Dimethylether as the source. The glass jar is about $5.00 and the power unit is about $6.00. Based on applying 5/6 coats per piece one should be able to coat 2 to 3 projects per power unit.
Preval units are available at most paint supply stores.
I echo what Russ said however I have to add one thing. The only place I have to spray is out my door with a fan at my back to keep the fumes away. I have constant problems with uneven finishes. I think it is a combination of constantly changing humidity and a cheap spray gun. I'm working on the spray gun thing but the humidity will be a forever problem. What I do now is spray and then level the finish with steel wool or other abrasive, followed by another coat and then continue.
It's definitely not the best system. With a little retarder and reasonably consistent weather I can get a good even cover but it's a forever testing thing.
I clean my gun once every 3 or so months just because I think it needs it. It still seems to spray fine. I use the mini touch up guns so I don't have as much lacquer in the gun at any time.
I use other finishes for most projects but lacquer has proven to be the best for my hand mirrors and christmas ornaments. I can get the kind of gloss I want on the ornaments and the hand mirrors are easily repaired if they get scratched or dinged.
Thanks Russ for all the information all I need to do now is turn something to try out the spray gun. I do have a quart size can of Deft to try. I read in your write up several other types, do you recommend using the more expensive lacquers once I practices with Deft or not? I don't think any of my work will end up in a museum.
I did pick up a Harbor Freight HVLP spray gun to work with my compressor several months ago but just have not got around to using it.
Is there a easy way of measuring out the 50/50 mix or do you just measure out on the side of the cup?
The "Critter" spray gun is great for your application. Amazon has it for about $40. Only needs a mediocre compressor. Clean up is a cinch since it uses mason jars. When you are finished with the lacquer put the cap on. Use another jar with a bit of acetone in the jar or from a can and spray a few spritzes and it s clean. Only drawback is that the pattern is circular and you can not change it but for bowls and so forth it is super, quick and simple to use. Depending on the weather I only use about 40 psi. Darryl
You can also get a rechargeable can for about $15. Same size as paint cans and you can charge it with your air compressor or a C02 cartridge. You can pull the nozzle and drop it in a small container of thinner in between. When the pressure is down open it up and pour in more product.
If you do a search on ebay for the following you should come up with quite a few.
(Rechargeable,refillable) Aerosol Spray Can
I have been use the same one for at least 20 years.
". . .do you recommend using the more expensive lacquers once I practices with Deft or not? I don't think any of my work will end up in a museum."
It depends on the wood and how long you want to keep the piece. Deft will turn yellow with age. This may not be a good thing on a light wood, but you will usually never know the difference on a dark wood like Cherry or Walnut. Some light colored wood, like Maples, turn a darker yellow on their own with exposure to sunlight, and the color of the Deft isn't as noticeable on them. The more expensive CAB-Acrylic lacquers will not turn yellow with age. The cheaper nitrocellulose lacquers are worse than Deft about turning yellow and often become a darker brownish color as they age.
How long it takes to turn a lacquer yellow depends on the wood and the environment, but I have had Deft on white Holly turn a yellow color in a year.
The real advantages to the Deft is that it is easier to use than the more expensive lacquers. Also, Deft can be applied with a brush or wiped on with a cloth, and that is not an easy task with the faster drying CAB-Acrylic lacquer.
An eyeball measurement is close enough. Depending on your gun, how you use it, temperature and humidity, you may want to add more thinner or use less next time. There is never a problem with using too much other than the lacquer being a thinner coat, and sometimes that is a good thing.
My answer to Dinyar's question about waterborne lacquers depends on the product. The old waterborne lacquers just built up multiple layers of a finish that looked like the clear plastic film on a book cover, and often peeled off as easilly.
There are a couple new waterborne lacquers on the market that burn into the previous coats the same as the old lacquers we are used to, and they look like a nitrocellulose lacquer rather than a sheet of clear plastic on the wood. I am experimenting with the one sold by Stewart-McDonald, the luthier supply company. The advantage is that it is ready to sand (if necessary) and recoat in an hour here in ID, but that may be longer in a higher humidity. The big advantagte is that there is no odor, it is harder, and it hasn't yellowed with age so far. These are new products and their real test will come over time.
The disadvantage is that the spray gun has to be thoroughly cleaned after every use. There is no leaving the finish in the gun for months like the old nitrocellulose lacquers.
The other disadvantage is that they are made for a spray application and they dry to fast for a brush or rag; but I am trying those methods anyway and finding they can be used if I am quick and willing to sand the surface smooth between coats.
Another product with possibilities is the new waterborne Acrylic from Deft. The real advantage of this finish is that it adds less coloring to the wood than wetting it with water. I have done maple with no color change at all, but with a nice high gloss without the plastic appearance.
The label says brush, wipe, or spray, but I have have not sprayed it, but I have used as a dipped finish on pens. Brush marks are a problem, but no more than brushing a varnish. It just means sanding between coats to remove the brush marks, but not having to wait a long time more than an hour or two before sanding. Wiping a tricky to do without leaving marks that have to be sanded away between coats. I haven't sprayed. But, I have dipped pens in this finish and it is no different from any other dipped finish except it dries faster and builds with only 2 coats, and it is harder than lacquer.
Again, this is a new product and time will tell more about it.
