Stumbled on this one while looking for ways to use a cell phone vibrator to try and get standing waves in a fluid it vibrates. Was after a way of adding movement to a shallow bowl - a pool of translucent liquid vibrating and creating patterns on its surface.
But THIS idea would be cleaner - and - potentially more interesting. Small diameter translucent, flexible tubing, a small recirculating pump and a couple of immisible fluids - colored or course - snaking into, out of and around a hollow form . . .
This was my first thought after looking at the video. It's already been done - Joseph Heller, Catch 22.
The soldier in white was encased from head to toe in plaster and gauze. He had two useless legs and two useless arms. He had been smuggled into the ward during the night, and the men had no idea he was among them until they awoke in the morning and saw the two strange legs hoisted from the hips, the two strange arms anchored up perpendicularly, all four limbs pinioned strangely in air by lead weights suspended darkly above him that never moved. Sewn into the bandages over the insides of both elbows were zippered lips through which he was fed clear fluid from a clear jar. A silent zinc pipe rose from the cement on his groin and was coupled to a slim rubber hose that carried waste from his kidneys and dripped it efficiently into a clear, stoppered jar on the floor. When the jar on the floor was full, the jar feeding his elbow was empty, and the two were simply switched quickly so that stuff could drip back into him. All they ever really saw of the soldier in white was a frayed black hole over his mouth.
If you want to experience a more common Catch 22, try not being poor enough to have a court apppointed and paid for by the court attorney, yet not rich enough to afford a private attorney, in no small part becausee of the other party in a court case. Now have the other party be "legally" a minor - a niece you spent eight years trying to get custody of - to get her away from her drug addict biological parents - each in a different state- and finally succeeded - only to find that the niece has severe mental problems - thanks to her biologic parents - and is TOTALLY out of control - and suicidal. And because, chronogically, she's still a "minor" THAT Catch 22 is bankrupting my pseudo adopted sister, destroying her business, tearing her immediate family apart and about to cause her to have a nervous breakdown. heart attack, stroke - or all three. I keep looking for the Mad Hatter, for surely she's fallen down the Rabbit Hole. Up is Down, Left is Right, Good is Bad, Bad is Good, Wrong is Right, Right is Wrong - and NOTHING means what it means in the world outside the courthouse. The Rules seem to go with No Good Deed Will Go Unpunished and No Bad Deed Will Go Unrewarded.
The ironic thing is the Other Catch 22 of this sad tale - no support services were available WHILE this "minor" was BEING used and abused and the court did nothing to protect her from that abuse. But NOW that the damage has been done - they're more than anxious to get involved - with helping her - while essentially destroying her aunt - who did everything she could to help this "minor" and to get help for her. If you think attorneys are expensive - hire a psychiatrist - AND - a psychologist - AND - pay for medications.
Sorry about the rant - my hot button got inadvertently pressed.
Kind of like one of those sequential kinetic deals, but needing constant tending. You go, watch it for awhile, say "cool", then go away. The memory of it is the valuable part.
Went out to pick up a pizza and on the way home stopped at Beverly's, a crafts store. Asked a clerk if they had any very small diameter flexible tubing - and got a blank stare. When I told her what I wanted to use it for - got a strange stare. When I asked if they had any plastic stuff to string beads on - a look of recognition - and an "Aisle 8 - but we don't have any small tubing/"
She was WRONG. They DID have - 2mm OD flexible tubing - probably the stuff used in the video I pointed to earlier. A buck ninety nine for 5 yards - and they had it in white, frosted, yellow, red and green. They also had the little plastic rod connectors to join ends - along with about 1.2mm OD solid, flexible, stretchy "line" in three or four day-glo colors as well as clear. AND - this stuff glows in the dark - but not very brightly.
The hollow tubing is called Pony Bead Lacing, the little connectors are called Pony Bead Connectors (DUH). the "line" is called Stretch Magic - again about $1.99 for 32 feet.
Somehow, I've GOT to learn to focus - on one or two things - and get things done. But there's so many cool things out there waiting to be used in ways not thought of by the makers.
A bowl - with a glowing laced rim. A John Jordanesque carved spiral hollow form - with lines of glowing light down in the grooves. Or a spiral braided finial - that lights up - or at least glows a little.
I saw this little stretchy tubing while making beaded bracelets and necklaces with my 5 year old grand daughter. Little kids have all kinds of slick toys to play with - and they're usually quite willing to share. I liked the idea - and so Kaitlin gave me a piece - to KEEP.
The idea of using tubing and a short piece of rod to join them is a slick solution to a problem. But I didn't see an application I could use - yet. After seeing the video of the hydraulic "thing" - it was easy to put two and two together - macrame the tubing and pump colored fluids through it - so OBVIOUS.
Had I not used this tubing to string beads on I'd have never found a source for it. Had I not stopped in at the craft store on the way back from picking up a pizza I probably would have forgotten the idea. Had I not asked where their Stringing Beads Stuff was - I probably wouldn't have 5 yards of little stretchy tubing to play with. The Serendipitous path to this interesting idea is a great example of "synthesizing" - combining apparently disparate things and ideas in a different way. Turns out that the more ideas and "stuff" you have to play with - for some of this requires Hands On experience - the more apt you are to see new combinations - you wouldn't have seen otherwise.
I'll play with this tubing stuff for a bit - and probably won't end up using it. BUT - by putting this stuff and some possible uses out here for others to see - MAYBE - someone else will see some other interesting possibilities - and pursue them. And if THAT happens - I hope the results are shared.
If you stop when the piece comes off the lathe - you may be missing a WHOLE LOT of other possibilities for the piece. And sometimes - if you start out with a Wild Hare Idea - and work back to the turning, making the turned part(s) is usually pretty easy.
