New this month from my lathe
Fred Holder
I'm certainly glad that we're back to posting about woodturning instead of politics. Since may of you are posting new turnings, I thought I would also post a couple of mine. The on on the left is a seven level ball done with Christian Delhon's tools and the one on the right is a five level ball made with the Crown tools. I hope this works.
Re: New this month from my lathe
Barb Siddiqui
Those are technically amazing.
Barb Siddiqui
karl jr
OMG I'd ask but you'd have to kill me
karl jr
Amazing!!!  nm
Toney Robertson
nm
Starry S Chan
This is really amazing work. Would you mind to share with us how you "turn" nesting balls?
Starry
Fred I hope to try one of those one day. I would really like the challenge of making the tools. I think I have the plans in one magazine so someday when I retire maybe I'll give it a try. You do a great job on these.
Fred Holder
Here is a brief summary of how I make them, but there is much more to it than described here:
Begin by Laying out 12 equally spaced holes on a 2-1/2 inch or 65mm round ball of good hard wood such as maple. I've used many different woods since I started making them in 1998.
Using Greenlee 34411 Kwik Stepper Electricians Step Drill, you can mount the drill in a Jacobs Chuck mounted in the Morse Taper of the tailstock and use this to position the ball in the chuck. Once the ball is locked down, you simply drill in until the last step shoulder touches the surface of the ball.
At this point you are ready to start doing the undercutting with the Crown tools. I recommend using a handle for each cutter so that you can simply do the undercutting for each level while the ball is set in the position in which it was drilled. It takes much less time to make a Chinese Ball with four handles than it does with only one handle.
Put the No. 1 cutter onto one of the undercutting handles, mine came with this cutter installed on the handle. Loosen the two holding screws and align the cutter to cut on the outside edge of the center (darkened in) sphere. The top of the cutter should not be up into the next dark ring. Tighten the screws and you are ready to begin. Set up your other three cutters in handles and set them to cut in progressively higher white spaces.
Set the tool rest so that the cutter is cutting at center of the work piece. Now, with the tool moved over so that the tool is aligned with the right (far side of the hole) and the tool handle is level, push the tool in until the curved surface of the tool is riding on the outer surface of the ball. (Note: It may take a little pressure while the tool cuts the top of the small ball to fit the shape of the tool.) Pressing the tool hard against the surface of the ball, gently move the tool to the left to undercut until it reaches the near side of the hole. Move the tool back to the far side and remove the tool from the hole. Assuming you have four handles one for each cutter, repeat this operation with each of the cutters while this hole is still set up. Blow out the chips. I use a straw, but you could use compressed air or simply blow into the hole and get a mouth full of chips. Install one of the tapered plugs into this hole and turn off any excess plug to the contour of the ball. Note: I cast my plugs out of Machining Wax in a mold made by the drill used to drill the holes.
Repeat the above operation for the other end grain point and then for all of the other 10 primary points. When you have finished all 12 holes, you should have 11 holes with plugs and one without.
This material is excerpted from my booklet, which is available for purchase at the More Woodturning website.
WayneLeach - NW Ont
Holy smoke-everyone on the forum are doing such amazing work I am being left in the dust!
Great job and quite a challenge?
Wayne
