Thank you and another question
Randy Gleckler
Thank you for everyone with their suggestions on how to get the design worked out on a piece, I'm trying several of them now to see which ones going to work out for me. As another question I've always wondered... Let's say your making a piece purely for scrap to test things on. Do you use some wood that may have checked and fill it somehow or do you use some better wood to avoid the checking?
Reason I ask is I'm tempted to use some whole logs turned to basic shape, but I get some pretty good checks in them... for testing as long as I have them filled, it won't matter... just need it to be a solid form. Additionally, they will be painted, so just wondering if it's worth filling the checks and if so, what the recommended way would be. Thanks in advance.
Re: Thank you and another question
John Veerkamp
Depends on the size of the piece and the checks. If the wood is dry enough not to check anymore, epoxy of Durham's Rock Hard Water Putty will work well. Either can be painted.
John
Steven Antonucci
I spend as much time as I need to figure something
steven antonucci
out...
If it involves hollowing or carving or whatever... if it's worth doing, it's worth doing right. Sometimes, I may need to make a few before I make one that I put my name on. I'm up to hat #5...
Steve
Maybe, but maybe not.....
A couple of thoughts.
Comes up here often, but John Jordon is credited with saying "Life is too short to turn Crappy Wood". There a lot of truth in that for several reasons.
Lets suppose you nail it first time out of the box. Then you will be disappointed that you have to do it all over again because you used crap wood.
What if its the crappy wood that spoils the design. You just can't get it exactly right because the crappy wood ruins the piece.
This is not to say you shouldnt do a prototype out of say ample or walnut before you jump on your piece of ebony or cocobolo you saved up for. Nothing wrong with doing mock ups, just be careful the wood does not defeat the purpose.
And, be careful. I know lots of people that have suffered injuries in the workshop, including myself, but the only two people I know of that were killed were working on the lathe. One of them was killed by a crappy piece of wood full of cracks that flew apart and a piece of it hit him so hard it killed him. I had a piece come off and hit me in the forehead. Took 27 stitches to close the third eye. So, John is right, Life is too short to turn crappy wood and crappy wood can shorten your life, or at least ruin your day. So, be careful and wear your personal protective gear.
Ditto to what Barry said
Carole Valentine
Mock-ups are great and I do them all the time, but use sound wood and it's a good idea to use the same species. Besides, any fill will probably affect what you are trying to do whether it is carving, burning, dyeing or what ever.
fgvanatta
I do like Barry said; I use what I consider less desirable wood - apple, oak, Philipine Mahogany. That way you haven't wasted your time; you still have a completed piece, just not with the flair of the exotic woods.
Frank
eliot d
The best piece of advice you received was from Bary. Turning wood that has cracks in it can be extremely dangerous. Here's the problem: let's say you're turning a good piece of wood and you're getting down to where it's fairly thin. Now suppose you get a catch, or if a hollow form, where you can't see inside, and you just happen to cut too far and you ruin the piece. Well, you're probably not going to get hurt; the piece will usually just rip up a bit and that's the end of it. But if you're starting out with a fairly large piece of bad, cracked wood, it can really fly apart at lightening speed and a large, heavy chunk can whack you! So listen to Barry, please!
