New mirror in progress
I have a 2 questions. This is a mirror I designed. Some of Vicki Jordan's wood. The original thought was to texture the weaving with lines so it would look a lot like a hickory bark seat. I think I've decided to leave it alone for now because I like the way the grain runs through it.
My second question is, how would you texture it. I want the lines to appear like rived grain so the lines would start right at the overlap of each joint. I can't figure out how to do it.
I thought about using a sharp cutting wheel on my dremel the same way I would carve hair on a animal. However that won't allow me to get right up to the overlap.
Then I thought about wood burning but that would leave the wood burnt. I don't want to paint over it to cover the burn and don't know how hard it would be to clean up the burn.
I thought about trying to scratch it with a sharp awl.
Any suggestions before I carve a scrap piece and give it a try.
I'm still working out the design of the handle. Hopefully what I have planned will work.
Re: New mirror in progress
Texturing
You can "groove" the surface by hand with the sharp points on a heavy carving burr or just 'drawing' your texture with a needle or sharp awl. However, your wish to preserve the grain presents a problem when your texture will have to go cross-grain on the simulated bands. Thus I'd suggest that you consider texturing only close to the intersections leaving the high spots on both the "warp" and "weft" smooth as if worn so from long use. You might also consider adding a bit of color to the textured areas to again simulate an age accumulation and thus give your carving even more visual depth.
Steven Antonucci
Perhaps a stiff wire brush?
steven antonucci
I like Mark's idea about the polished high spots...
Your handle should be some play on a hickory rocker/spindle...
S
Re: Perhaps a stiff wire brush?
Carole Valentine
I like the idea of worn smooth as well. Good job, John...I have been playing with this weave pattern on scrap wood off and on for a while and it sure is difficult and time consuming to get right. In fact I may NEVER get it right!
fgvanatta
How about a very small burr in a Dremel tool . . .
Frank
Michael Mocho
Hi John,
I've found that a wire wheel in a drill (radial, not cup bristles) leaves a very evenly scratched surface. The challenges it to get it even, and the cross grain sections may look quite different from the places where the wire bristles wash out the softer grain. Variables will be stiffness or softness of the wheel, diameter, RPM, pressure- and mostly wood hardness and density of annual rings.
Good luck!
I like the worn concept-thanks mark
The hardest part is making the first 5 or 6 cuts. It's so hard to figure out what parts go under or over. I understand now why Sharon Doughty spend so much time on the layout of her celtic knots. It's even more critical when you have tu cut away wood.
Michael living this close to John Jordan I've played with wire brushes a lot. I probably own 6 or 8 different ones. On this project they just won't work. I can get close to the overlap sections which I think is important.
As you said it also gives a different look across the grain vs with the grain.
I'm going to go out and try very small carbide dental burr that I have. I think I can drag it parallel to the shaft of the burr and get a good cut unless it tries to run sideways.
Sometimes you just can't do it with a machine, John. My suggestion of the needle or awl will let you "draw" your texture into the surface just as fast as you would using a pencil to do simple line shading on paper. In fact, it will be faster that your burr, I think.
Carole Valentine
The only way I could figure it out was to draw it on the wood and then shade the over/under pattern with a pencil. If I didn't do that, I was sure to screw it up and go over when I should have gone under or vice versa.
Take this with a grain of salt, because texturing is not my thing. But then, I am always outside that box, because I have no idea what's in the box.
How about a piece of hacksaw blade with about five or eight teeth mounted like a rake? And just rake the dickens out of the grooves?
I know, I know!!! Use one of your thread chasing tools. Or make one with ragged teeth.
On some of my turnings I have use very coarse sandpaper (24 or 36 grit) and texture a ring around them. You might try using a tiny piece of floor sanders sandpaper.
Are you planing to cut the weave into the rest of the surface? I kind of like it as it is.
Re: I found that shading ....
JamieDonaldson
the junctions of the weave patterns really adds dimension to the results. I have used burners, stains and marking pens, and rubbing out gives a worn appearance.
You Mean
To say I didn't think of that first!
Well, I DID, actually but it was in a prior life so how dare you plagiarize my idea, Jamie!!
[Nicely done, by the way] ;)
I built a paper mockup to keep me straight
Interesting idea Barry. You can buy hacksaw blades in a wide variety of tooth sizes. The same is true with jigsaw blades. There may be a new tool in my arsenal.
Nice piece Jamie. I thought about shading but decided I want this one more natural.
Matt Overton
it's funny you posted this pattern today. I just spent a week with my Boy Scout Troop at summer camp helping them make stools and baskets for the basketry merit badge. I love your idea for this mirror.
Leo Cuellar
Leo Cuellar
Very nice John. Can't wait to see it finished! If Barry's suggestion doesn't work, you might have to resort to carving them individually with a fine v gouge or engravers tool, a checkering tool might be an option but tedious. :\
