JT Transformer Hollowing Tool *LINK*
jake Niedling
A buddy of mine is looking for an hollowing system with an adjustable tip. He asked me about the JT Transformer system, but I am not familiar with it. Anybody have it and have comments? I am sure he would like any other suggestions that you might recommend. Thanks. I have attached the link below. Jake
http://www.jtturningtools.com/trans-former
Re: JT Transformer Hollowing Tool *LINK*
Re: I "tested" it at SWAT last and ....
JamieDonaldson
know the builder, and his tools work well. I did not add any to my tool "collection" but would not hesitate to do so if I had need of such equipment.
Wally Dickerman in Arizona
Jake, I have a Nichols hollowing tool that is very similar. The gate or tool holder is identical. The tool itself is constructed much the same. It can be used right or left handed.
The Nichols hasn't been made for a number of years but Don Derry makes one that is nearly identical. Don's has a laser installed. Don has a website.
I've had my tool for perhaps 15 years. I use it for deep pieces because it gives me good control. The concept of the tool is very good IMO.
Wally
Steven Antonucci
interesting design
steven antonucci
if you make larger forms with openings that fit, I could see using the tool. My question is would it be advisable to have the larger cutter inside the form? I've spoken to a lot of people and conentional wisdom is that the larger cutters are pretty 'grabby' if used for hollowing.
Is this tool only meant to clean the inside up with a finshed shear cut? Or is it used in place of the Ellsworth style cutter?
S
Re: interesting design
My Nichols tool uses either a 1/4 or 3/16 square cutter for hollowing and has a unique 3-piece scraper for cleaning up. The scraper can be adjusted to expose as much of the blade as is wanted. Not grabby at all. A similar one could be designed for this tool.
Wally
