Let There Be Light *LINK*
charlie belden
If you're expecting bright flashing strobe light - sorry to disappoint. Figured out a simple - and cheaper - way to get light from INSIDE a piece to the OUTSIDE of the piece - using 1/16" diameter flexible clear acrylic rods you can get from TAP plastic. MUCH easier to use than fiber optic cable - at 1/3rd the price. AND - you don't have to deal with stripping the outside insulation - and cutting some of the tiny little fiber rods inside by accident.
A Red Green Blue LED inside is shrunk tubed to the inside ends of the acrylic rods and scrolls through the spectrum. By "flame beading" the outside ends of the eight acrylic rods, you see crinkled little spots around the piece when the LED is off - and when triggered by a light detector that will go on the top of the finial - the fade from red to blue to green run through the spectrum routine will start.
Did a one minute YouTube video to show how the lighting thing performs. For the video I set the brightness of the LED up so you could really see its light. I'll tone the brightness down in the finished piece. The vid is sort of like watching paint dry - but it does show the semi-subtle, changing lighting effec.t
I'm documenting the use of an Arduino stamp controller on this three part The Three Sisters piece and will be putting up some web pages of that stuff. Lots of "challenges" - but most have simple solutions - that I'm finding - after trying the complicated solution.
Comments and questions welcomed.
YouTube vid of RGB lighting idea
Re: Let There Be Light *LINK*
Toney Robertson
Very cool Charlie. I think it is a concept that could be taken in many directions.
It would seem that Fiber Optic would have more possibilities. I have thought of trying some of that myself.
Great execution on this piece.
Terry Scott
Man you are having a blast
The research and the how? must be what drives you
Having these light up as someone walks past them for a couple of flashes would really get people wondering whats going on
what id like to know is if we have to call you MR ET Belden
Norm Smith
Geeezzzz Charlie, You come up with some great stuff.
Thanks,
Norm
ET?
charlie belden
If, by ET, you meant Electronic Tech - NEVER! I don't care HOWsensors and stuff do what they do - only interested in how to get them to do WHAT I want them to do.
What I hope to do is put together some info that will make it a bit easier for The Next Guy to play with this stuff.
Now if ET is referring to the little Extra Terrestrial - a thin walled NIP hollow form - with a glowing heart would be interesting. Could have the piece also say "ET phone home" in a weird voice - and then make a ringing phone sound . . .
Hmmmmm . . .
