Platter Carving?
Platter Carving?
Platter Carving?
jake Niedling
I have a 10" platter that I plan to do some carving / surface texturing to a large portion of the top rim. What is the recommendation for the back side of the platter ( leave smooth or carved )? If carved, should it be the same pattern as the top? My thoughts are that both sides should be carved or textured. Also plan to color it as well when I get done. Appreciate all comments. Thanks, Jake
Re: Platter Carving?
Don Evans
Have you considered how you will display it? Wall hanging or in a stand on a table etc?
The answer to this would also help make the decision. I've never done the back on a platter due to the above displaying methods for platters.
There is also the chance that the back decor may turn out more appealing than the front. :D
The correct answer to this question is what ever you decide to do is the way it should be done.
Don
Jake I usually only carve or texture the unseen part to make it a surprise to people handling the piece. When they pick it up they feel the underside. That makes them turn it over and adds to the discovery of the piece. That being said, I only do that on rare occasions for very special pieces.
Ralph E Watts
Jake,
Wish I was there to consult! Glad to see you moving into new? territory.
-Both sides? Double the work...
-One side-might seem unfinished...
Hummm such a dilemma..
Looking forward to a posting on the results.
Best regards, Ralph
Richard Allen
Richard Allen
I did a series of 5 platters a while back from plain to full burn, color, carve, metal leaf top and bottom.
I generally just burn and color the top rim now.
Terry Scott
Jake I carve both sides have a look at my web site under platters www.timberly.co.nz
I go a bit over board but this may give you some ideas
I like that surprise factor when a customer picks up a platter and they voice oh my look at the back
I am no expert at carving but if you email me I am only to happy to brain storm
Cheers
