need new tool and new measuring gauge
I tried to turn a small hollow form the other night but wanted a little different shape with a recessed top and small opening. The tool I used to hollow just under the rim won't reach far enough to go to the upper corners. The tool I used to do the bottom and part way up the sides won't reach any deeper than you can see. Unfortunately it will reach deep enough to cut through the bottom. This vessel is about 4" wide and about 2" thick.
That's where I found out that I needed new measuring gauges. I simply could not get in and read the wall thickness on the sides at all. Consequently after I ruined it I cut it in half and will sit down in the next week or so and design some new tools and measuring devices that will get into those areas.
), so here I thank you and encourage you (and others) to continue posting these learning opportunities as well as your successes.
