It's been a long time, too long, since geometry in school and I need some design help.
Think lamp shade, funnel shape with top opening much smaller than bottom opening.
I think it would be drawn out on flat surface with two lines top to bottom and they would angle out from each other as you drawn then top to bottom. Then two lines horizontal connecting the vertical lines at top BUT this line would dip in middle, same with bottom horizontal line.
My problem is how does one figure what angle the two vertical lines need to be?
The finished measurements aren't absolute but when the thing is rolled up the top opening would be about 4" diameter and the bottom opening about 10" diameter. From top to bottom about 8".
I plan to draw this out of construction paper, then use it as template to cut it out of flashing.
If I understand the question correctly, you want a standard lampshade shape. The top and bottom lines are actually not straight, but a section of a circular arc if rolled out onto a flat surface.
I was one of those few kids who actually enjoyed geometery..... ...what you need to search for is information on a "frustrum" which is essentially the form a lampshade is - a frustrum of a cone.
The link below is for a Wikipedia page that explains the general geometric form of a frustrum, however you could simply search on "frustrum" in GoogleImages, and you will see quite a number of graphics which can help you figure out what dimensions you need to develop your template.
Don, I cannot help you with your geometry issues but I am darned glad it is not Monday because you've made my brain hurt with all this math. Good gawd man, put a more severe warning in the title or something!
I make buckets out of staves and I think you are headed in the same direction as I have to look in terms of the compound angles.
I use bandaw jigs and emperical methods for the buckets, but there are several computer programs that allow you to calculate stave angles and dimensions to achieve the lamp shade effect with staves. I have one of those programs on the computer, but google search will show sites with stave calculation programs available. I usually use 12-16 staves for a bucket.
The lampshade from a log does not need much geometry other than diameters and length -- and careful jigging!!!
Don, if you can lay your hands on a US Navy rate training manual, Steelworker 3 and 2, it will have more information than you ever wanted to know. I could not find my copy.
