Simple layout using the lathe
steven antonucci
I have used the indexing on my lathe to help lay out the grid for a spiral. If you think about how many twists you want, you can pick off the index points to create evenly spaced vertical lines. Next, make horizontal line so that your vessel is covered in a "grid".
Usually, I try to make my pattern appealing by controlling the decay of the spiral. If you pick a grid point, you can wrap a piece of tape down the grid, noting the intersection points, then draw a line. Continue moving the tape until you have all of the lines you need.
As John Lucas mentioned, getting the wood out is an all hands task using whatever you have. I have made rough spiral patterns using a chainsaw disk on a grinder, all the way down to fine sandpaper... whatever it takes!
Steve
